Slapping wires in mast. - SailNet Community
 1Likes
  • 1 Post By GaryHLucas
post #1 of 6 Old 07-31-2012 Thread Starter
L124C's Avatar
The internal electrical wires in my mast slap as the boat rocks. I know this is a common problem, but think there must be a solution (searched this forum without results). Not only is it annoying, but it can't be great for the wires.
I thought about pulling the lower Halyard sheave and inserting something inflatable beneath it. Problem is, even IF I could do it, this would impede the flow of water from above. Anyone have a solution. Do some manufactures install a conduit inside the mast? I would think this would be easy enough to do during manufacture. Thoughts?
Edit: After searching, posting this thread and receiving replies, I found this thread in the "similar thread" Wires slapping in mast section at the bottom of the page. Don't know how I missed it as I searched "slapping wire". Oh well, more good ideas there!
L124C is offline
post #2 of 6 Old 07-31-2012
Re: Slapping wires in mast.
I had this problem for years. It's very annoying, indeed.
Unfortunately, there's no good way to stop it, at least none which won't have problems later on.
The usual "fixes" are: foam, wire ties at various intervals, arranged in triangular form, etc., etc.
The only real way to fix it, however, is a proper conduit. And, this can normally only be done with the mast down.
A PVC conduit for the mast wires is inserted the length of the mast, and secured to the mast with aluminum rivets.
Yes, most manufacturers have some sort of conduit installed when building the boat, but you may have the same problem I did: a previous owner adding internal wires without passing them thru the existing conduit.
Good luck,
Bill
btrayfors is offline
post #3 of 6 Old 07-31-2012
I am doing my mast right now, the same way I did a previous one 25 years ago. I cut 'donuts' from polyethylene foam (trade name Ethafoam). A notch at the front of the mast carries the electrical wires, the hole in the middle carries all the halyards. The wires don't slap, and the halyards never touch metal, absolutely quiet. I use the whisker pole to push the donuts in from both ends of the mast spacing them about 3 feet apart.
Gary H. Lucas
GaryHLucas is offline
post #4 of 6 Old 08-02-2012 Thread Starter
L124C's Avatar
Thanks! Two questions: The Halyards don't wear the foam down? Are you at all concerned about the donuts holding water inside the mast (even if it is fresh)?
Gary H. Lucas
L124C is offline
post #5 of 6 Old 08-02-2012 Thread Starter
L124C's Avatar
I assume you drill holes for the rivets on Port or Starboard (not fore or aft) to minimize weakening the rig. I assume the intrusion is minimal (and I have a stout spar) but I would want to do it strategically.
Good luck,
Bill
L124C is offline
post #6 of 6 Old 08-02-2012
Polyethylene foam is very slick, and halyards don't move much except when raising or lowering the sails. The foam cost so little, and replacing it when you take the mast down is no big deal, if it wears excessively. It doesn't absorb water, and tilting of your boat will ensure that water on top runs off pretty quick. Besides you mast gets hot in the sun and drives off any moisture. Way less of a problem than the foot of a mast sitting in a wet bilge!
Gary H. Lucas
juggleandhope likes this.
Help identify mast wires turbulicity Gear & Maintenance 11 04-15-2012 02:27 AM
Running Wires Down The Mast of a '78 Catalina 30 eyevandrago Electrical Systems 4 01-30-2012 03:49 PM
Wires slapping in mast wchevron Gear & Maintenance 12 05-09-2010 09:35 AM
Sealing wires into the mast head jarcher Gear & Maintenance 9 05-27-2009 03:28 PM
wires going up the mast - where do they go in? jarcher Gear & Maintenance 4 10-10-2008 04:43 PM
