Spar varnish or polyurethance for steps? - SailNet Community
post #1 of 4 Old 07-31-2012 Thread Starter
I'm refinishing the companionway steps, and can't decide between spar varnish and polyurethane. I guess there's a third option, spar for the verticals and low gloss poly for the steps.
Any thoughts?
MarkSF is offline
post #2 of 4 Old 07-31-2012
RichH's Avatar
Re: Spar varnish or polyurethance for steps?
Neither.
Spar varnish is too flexible and too easily marred/dented, etc.
Polyurethane is also too 'soft' and will easily mar.
Seek out athletic gym floor / high traffic floor varnish or HARD 'bar top' varnish. Hard bar top can sometimes be found in old fashioned paint stores (the proprietor usually has to 'make' it for you - special order).
If you want low gloss (satin) forget the chemically 'wrinkled' soft varnishes. Instead use a durable gloss hard varnish, then hand rub with a mix of pumice and oil. Do websearch for "hand rubbing" + varnish + satin
RichH is offline
post #3 of 4 Old 08-01-2012
Sailor
Gladrags1's Avatar
Ultimate Sole was the perfect product for what you are doing. Unfortunately, it is no longer being made, victim to the rules outlawing certain paints due to high VOI and the company is no longer around. In the land based world, it was known as Gym Seal for gymnasium floors; hard, glossy and non slippery when wet. That too is gone. Check with a paint store (non big box) and see if there is a replacement. If so, let us know as we eventually will need to touch up out sole and we don't have too much Ultimate Sole left...
Tod
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #4 of 4 Old 08-01-2012
JimsCAL's Avatar
Did mine with Minwax semi-gloss urethane varnish. Seems to be holding up pretty well.
JimsCAL is offline
S2 11.0 Spar Supplier? patrscoe S2 5 11-07-2011 08:18 AM
Z-Spar Flagship Varnish and Ultimate Cabin Sole 1970Columbia34 Gear & Maintenance 9 01-25-2007 02:37 PM
Spar cleaner & wax TrueBlue Gear & Maintenance 0 02-15-2005 07:25 AM
Stepping the Spar Tom Wood Gear and Maintenance Articles 0 09-15-2002 08:00 PM
Spar Speculation Sue & Larry Gear and Maintenance Articles 0 07-03-2001 08:00 PM
