How to do compression check? - Page 3 - SailNet Community
 2Likes
post #21 of 25 Old 08-03-2012
Old enough to know better
Re: How to do compression check?
Originally Posted by IronSpinnaker View Post
They actually only tell you anything if done on a schedule with the data trended on a graph. All engines have wear metal present in the oil. The presents of wear metal means the engine works. The oil analysis only shows you the rate of deterioration if you have multiple points of reference over time.(like at scheduled oil changes) 10, 20, or 30 % increase in wear metal in a three months scheduled oil change is normal.... 100% increase in the same amount of time is bad.
They can tell you if something is out of wrack. Blackstone has a pre-purchase test kit (includes a pump to get oil out) and will give results same day they receive the sample. I agree it is not as good as a trend, but it could find coolant from a small leak in the head gasket, the most common issue. It will show very high levels of metals if there is a bad bearing. It can also indicate if the oil has not been changed in a long time. There is a lot of info in there. I have no interest in Blackstone, but have used there services in the past and found it to be useful information.
miatapaul is offline
post #22 of 25 Old 08-03-2012
BarryL's Avatar
Originally Posted by dsmauney View Post
Thanks Barry.
What I am asking Iron is the following. When he offers the opinion that a responsive start on a cold engine is a sign of good compression does that include using glow plugs on engines, like the M25xp, that have them. Response from anyone that has experience with diesels would be appreciated.
Goodwinds
DaveM
Yes. If an engine has glow plugs, they should be used for a cold start test.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #23 of 25 Old 08-03-2012
Geoff54's Avatar
Thanks Barry.
Goodwinds
DaveM
Yes - if you have glow plugs, use them. An engine with poor compression will usually be harder to start and often idle unevenly, although both conditions can be caused by other things.
Geoff54 is offline
post #24 of 25 Old 08-04-2012
Boatswain
IronSpinnaker's Avatar
Yes; use them. A Pre-chamber Diesel is designed with lower compression than a Direct Ignition Diesel, which is why they have glow plugs.
Ignition takes three things, fuel air and heat. In a Direct ignition diesel the compression of the fuel and air causes the heat for ignition. In a Pre-Chamber diesel glow plugs are used to gain the heat at a lower Compression. If you have glow plugs your engine was designed to be started with their use. It will start without them usually, but it will be much harder and that is normal.
You can see blowby if you remove the oil cap, you would have exhaust coming out the fill spout. That would be a very good indication that engine has significant wear.
Signature
IronSpinnaker is offline
post #25 of 25 Old 08-04-2012
Thanks Iron. Neat idea on oil fill cap. Appreciate other input.
Goodwinds
DaveM
dsmauney is offline
Compression posts cherokeelullabyII Cruising & Liveaboard Forum 3 06-20-2011 01:37 PM
Compression test brokesailor Pacific Seacraft 14 02-09-2011 08:48 AM
Who needs compression? davidpm Gear & Maintenance 23 10-10-2008 10:10 PM
4-108 compression? Capnblu Gear & Maintenance 4 05-27-2008 12:17 PM
Compression Post? SailOntario Gear & Maintenance 11 08-24-2006 09:03 AM
