Keel material on a CAl 27 T2 - SailNet Community
post #1 of 3 Old 08-01-2012 Thread Starter
mikehoyt's Avatar
Does anybody know what the Cal 27 T/2 (or Cal 27) used for keel material? Is it lead or iron?
Mike
Mike
mikehoyt is offline
post #2 of 3 Old 08-01-2012
Lightbulb Re: Keel material on a CAl 27 T2
Lead, per an on-line brochure.
Actually, I'm pretty certain that all of the larger 70's Cal boats had lead ballast.
http://www.richardanderson.net/TechS...20Brochure.pdf
olson34 is offline
post #3 of 3 Old 08-01-2012 Thread Starter
mikehoyt's Avatar
thank you
Mike
mikehoyt is offline
Questions about barrier coat on steel keel, and sealing keel joint EricinToronto Gear & Maintenance 1 04-21-2012 09:43 PM
rubbery material at hull-keel joint - what to replace it with? Bene505 Gear & Maintenance 11 03-22-2010 12:21 AM
Filler material around keel KB7EWA Gear & Maintenance 3 06-06-2009 09:34 AM
Best keel fairing material dargiem Gear & Maintenance 6 09-30-2006 07:07 PM
Hunter keel material nauticalrich General Discussion (sailing related) 1 07-30-2002 09:01 AM
