C&C 30MK1 main sail slug size? - SailNet Community
post #1 of 9 Old 08-01-2012 Thread Starter
First String
I have replaced the slugs off the main sail on my C&C 30MK1 not sure but it seams to get stuck a lot what raising and lowering the sail? I may have used the wrong size? Any Idea the correct size for this mast?
Thanks for any help.
Curt
ltgoshen is offline
post #2 of 9 Old 08-01-2012
Junior member, rest old
msmith10's Avatar
Re: C&C 30MK1 main sail slug size?
I'll be at my boat Friday and will measure them for you then if you don't get another answer first.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #3 of 9 Old 08-01-2012 Thread Starter
First String
Thanks. The ones on my boat seam to be too small. My main gets stuck gowing up and coming down. I will be wanting to single hand this boat later and need the hank on sails to be smoth. Thanks for your help. I think they may be 3/4 but not sure.
ltgoshen is offline
post #4 of 9 Old 08-02-2012
Remember you're a womble
PaulinVictoria's Avatar
Have you cleaned the track and lubed it?
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #5 of 9 Old 08-02-2012 Thread Starter
First String
UH! no. Your suspose to clean and lube the track? I will lookinto that. HAHAHA . sorry new at this. It just looks like the slugs are catching in the track like they are too loose.
ltgoshen is offline
post #6 of 9 Old 08-02-2012 Thread Starter
First String
When the sails are overpowered with wind and the boat heels excessively, bleed some of it off. Even though power is decreased, the boat may find better footing and sail faster.
Right?
ltgoshen is offline
post #7 of 9 Old 08-02-2012
msmith10's Avatar
Excessive heel will slow you down and increase weather helm, which will also slow you down because you'll be applying constant rudder to hold course. There are lots of things you can do other than just easing the sails off. I'd highly recommend a couple of books: Sail and Rig Tuning, Ivan Dedekan or North Sails "Fast Course". They'll tell you a lot about adjusting your rig and sails for different conditions.
The C&C 30 will handle quite a lot of weather if you know how to tune it. Ease the traveler then the mainsheet if necessary to reduce weather helm. Flattening the main (tighten outhaul and vang) will help depower. tightening the backstay will help flatten your genoa. You'll want to reef the main or downsize the jib if you still need to depower. During a race upwind if I'm overpowered I often just let the main off until it's backwinded considerably-- C&C sailors jokingly refer to this as a "speed bubble."
There's really a lot to learn and I'd recommend the above books
Mark Smith
msmith10 is offline
post #8 of 9 Old 08-02-2012 Thread Starter
First String
The C&C 30 will handle quite a lot of weather if you know how to tune it. Ease the traveler then the mainsheet if necessary to reduce weather helm. Flattening the main (tighten outhaul and vang) will help depower. I have a stiff arm or boomvang . do you mean flatten the sail by dropping the boom? tightening the backstay will help flatten your genoa. You'll want to reef the main or downsize the jib if you still need to depower. During a race upwind if I'm overpowered I often just let the main off until it's backwinded considerably-- C&C sailors jokingly refer to this as a "speed bubble."
The other day I was on a close broad reach and the boat was at 20% and I let the main out the boat went to around 12% and excelerated nicely. So I guess I had her too tight?
ltgoshen is offline
post #9 of 9 Old 08-02-2012
msmith10's Avatar
Get telltales on your main and jib and learn to use them. The books will explain. The longer I sail (50 years now) the more telltales I add.
Mark Smith
msmith10 is offline
Sail slide / slug shackle size? MITBeta Gear & Maintenance 3 05-09-2012 04:46 PM
Sail slug track gate question? OldBlue P30 1 07-13-2011 03:00 PM
Main Cunningham Size/Purchase/Line max-on Gear & Maintenance 5 06-06-2008 11:11 AM
Sail slug Bardo Gear & Maintenance 4 09-25-2007 09:55 AM
Convert sail from bolt rope to slug sliders? CrunchyBits Gear & Maintenance 6 01-20-2007 12:28 AM
