08-02-2012
Junior member, rest old
Re: Does the prop shaft need to touch the back of the transmission?
As Tom said, the face of the shaft coupling should be trued in a lathe by a machine shop. Otherwise if it's not absolutely square to the shaft you can never align it properly. They can also drill the dimples.
It doesn't matter if the shaft is all the way in. The force is transferred by the coupling. After all, if the shaft can push against the transmission flange independent of the shaft coupling, it could also move back in reverse. That's a bad thing.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
