Water under cabin sole - SailNet Community
post #1 of 4 Old 08-02-2012 Thread Starter
I have a 1979 Morgan 41 OI. There always seem to be water under the cabin sole. I don't see a way to drain this to the main bilge under the motor. Any suggestions will help.
topboatguy@yahoo.com
Topboatguy is offline
post #2 of 4 Old 08-02-2012
Re: Water under cabin sole
Is it ..fore or aft? Is the boat sitting on it's lines? Could you add some weight or shift weight to help it move toward the bilge?
tempest is offline
post #3 of 4 Old 08-02-2012 Thread Starter
Thanks for the reply. There dosen't seem to be a scupper or opening to the bilge under the motor. When sailing, a weeping of old water appears on the forward engine room bulkhead just in front of the engine. Any ideas?
post #4 of 4 Old 08-02-2012
Sounds like it could be the water from the drip around the propeller shaft? Unless there's a leak from somewhere else. You could simply drill a small weep hole in that bulkhead IF it would then allow the water to drain to the bilge? Is it possilble that there is already one there and it is simply clogged?
If you drill a hole you might want to consider doing a bit larger hole, filling with it epoxy and then driling a smaller hole in the epoxy. This would keep the wood member from soaking up water through the cut edge, or fitting some kind of stainless sleeve that gets expoxied in ? Just a few rambling thoughts.
tempest is offline
Cabin Sole - Before & After Tanley Gear & Maintenance 16 01-05-2014 10:08 AM
Cabin sole Dmarina Gear & Maintenance 7 04-27-2011 11:12 PM
Cabin sole sandyv38 C & C 3 12-17-2010 01:53 PM
Cabin sole Dcneuro Gear & Maintenance 16 09-27-2008 08:34 AM
Cabin sole nelsonsmoody Gear & Maintenance 9 11-07-2006 11:40 AM
