Spraying gelcoat - Page 2 - SailNet Community
post #11 of 13 Old 08-04-2012
bljones's Avatar
Re: Spraying gelcoat
Any decent quality air tool will have the cfm req at either 40 psi or 90 psi listed on the box.
It's 5 o'clock somewhere:
bljones is offline
post #12 of 13 Old 08-04-2012
tommays's Avatar
http://multimedia.3m.com/mws/mediawe...y%20System.pdf
3M™ Accuspray™ System. HVLP Primer Gun which runs on about the lowest air possible (a good 3 HP will keep up )
It is a kick-ass product the disposable parts are CHEEP and the PPS cups let you spray solvent in seconds with ZERO mess
The PPS cups come in a bunch of sizes and save you a LARGE fortune in clean up solvent use and disposal
Its still really dangerous once you go beyond the preval sprayer or a small gun like the SATA mini-jet
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #13 of 13 Old 08-04-2012
"Sparkie"
j34035's Avatar
Do not forget a good respirator. Never spray without one!
DD
Doug
Jboat J/37c (new to me Jan 2011); J/22 #1003
j34035 is offline
Spraying VC 17 j34035 Gear & Maintenance 13 03-04-2010 02:28 AM
Spraying AwlCraft Using Brushing Converter? geoffschultz Gear & Maintenance 3 04-26-2009 10:06 PM
gelcoat or not to gelcoat? marcusn Gear & Maintenance 2 05-30-2008 02:44 AM
Spraying Primer on 1970 Columbia 34 1970Columbia34 Gear & Maintenance 0 12-17-2006 10:12 PM
Spraying gelcoat replusted Gear & Maintenance 1 04-20-2002 08:12 PM
