Cetol Vs Honey Teak - Page 2 - SailNet Community
post #11 of 16 Old 02-11-2004
Cetol Vs Honey Teak
Has anyone heard of Penofin? It''s a marine finish that blocks 99% of UV rays. I am thinking of trying it on a swim platform. Anybody know anything?
lauralee is offline
post #12 of 16 Old 02-17-2004
Cetol Vs Honey Teak
The proper way to assure yourself of a finish that lasts is to completly seal the wood (almost impossible) yes that means every edge and or surface. Other than droping something like a winch handle,or wearing cleats onboard the most likely place for your finish to lift is where you attach it to the vessel. very few people go to this lenght to finish a brightwork area,(I don''t) I would rather sail than have a museum piece)so the shortcut is to tape off the deck and carefully cut around the piece in question.perhaps it would be extreme but if you drilled out the screw holes a bit and filled them with epoxy then finished the wood,rebed it and reattach to vessel the finish would not fail other than the uv problem. I suppose someone will have to invent plastic teak that doesn''t deteriorate.
newuser is offline
post #13 of 16 Old 02-17-2004 Thread Starter
Mr. Bill
Cetol Vs Honey Teak
Thank kend & All, I think you''re right about sealing every edge. The problem of coures is getting thing off intact, removing the bedding, epoxy/varnish, and then re-bed. But since I''m starting from scratch with new teak, hopefully I can do the job right, the 1st time.
I''m still struggling with how to drill the holes through the hand rails for the thru-bolts, without a drill press. I''ll probably need to pay someone. After that, I think it''s a simple matter of installing the bolts, epoxy them in, add the caps and expoxy everthing. I''ll be curious to see how easy the old handrails come off.
e-27 sailor is offline
post #14 of 16 Old 02-18-2004
Cetol Vs Honey Teak
e-27
There used to be a tool that attached to a drill called a portalign,it''s function was to allow a person to drill a hole perpendicular to the plane it was set on,Ideal for drilling on round surfaces. Unless you are filling all the old holes and attaching the rail somewhere other than the original spot you can mark holes from old piece and drill. Also a side note since you are pulling the old ones off, and more than likely putting them in the same place, take the time to drill a larger hole where the bolts came thru and epoxy them then redrill the proper size hole for the bolt this will also keep moisture from entering your hull.by the way you can buy an inexpensive bench type drill press or a base for your drill for less than fifty dollars. good luck with your project.
newuser is offline
post #15 of 16 Old 02-18-2004
Cetol Vs Honey Teak
On Cetol, I initially like the finish and really liked easy maintenance. But after 5 years of application to the letter of the instructions, the finished teak noticablely darkened, alot, and areas that needed repair would not match at all. Then it all started peeling off -- as water got under scratches, etc.
In retrospect, I think putting the gloss finish on top of the light version would be a way to go to prevent buildup. Fortunately, I sold the boat, so that''s someone elses project. My new (to me) boat has varnish on the teak, so I think I''ll go with that for the time being and see how it goes, and if technology ever triumphs over weather and sun, and wear and tear, then I''ll rethink it.
wheelerbrian is offline
post #16 of 16 Old 07-02-2014
Re: Cetol Vs Honey Teak
Interesting topic as I've used both.
I had cetol on my last boat and it didn't last 20 days at sea - the salt cooked on from the trans-At chewed right threw it....which was fine and I went grey for the rest of the 3-yr cruise.
Since, I bought a boat with WAY too much teak on it - Shannon 43 Ketch - that had honey teak on it. I've been trying it and I can see why the previous owner used it sailing in Maine and NS. Down here on the Chesapeake is a lot more sun but the literature says it will last 3-5 yrs with minor maintenance...I'll believe that when I see it.
So far, it's easy to use - damn expensive, but does go a long way.
I really like the epoxy varnish idea...if I ever want to spend a month of stripping and revarnishing....NOT!! I bought this boat to cruise and sail...not yachtify it.
sati8d is offline
Advice refinishing teak and holly sole mcagney Gear & Maintenance 23 04-26-2017 10:38 PM
Teak or no teak... Keyne Boat Review and Purchase Forum 20 08-10-2006 06:08 PM
Need a small piece of Teak bottomfeeder Gear & Maintenance 3 03-08-2004 07:16 PM
Teak deck Q ekhar Gear & Maintenance 8 03-10-2002 05:48 PM
3M 5200 & Teak Cleaners mikehoyt Gear & Maintenance 1 11-22-2001 04:57 PM
