Homemade Permanent(?) Dinghy Paint - SailNet Community
 1Likes
  • 1 Post By tanksalot
post #1 of 4 Old 08-04-2012 Thread Starter
Having goten tired of scraping goo off my Dyer dinghy's bottom, and realizing that metallic copper inhibits marine growth, I made my own bottom paint for less than $30. (Not as simple as just buying some bottom paint, but a lot more fun and interesting).
Since putting copper powder INTO a paint covers most of the copper with the paint binder, I tried a different approach. First, I sanded off the very old bottom paint and painted it with clear 2-part epoxy, slightly thinned.
Then, while the epoxy was just starting to cure, I sifted a very, very fine copper powder ($20 from ebay) onto the epoxy. This left the exposed surface of the dinghy as pure copper. I did the same with an acrylic panel, so I wouldn't have to pull the dinghy whenever I got curious.
I hung the acrylic panel from the dock near my boat, and have put dated photos into an album, Pictures by tanksalotct - Photobucket .
The most interesting aspect of this is the "windows" that are clear. I didn't paint the windows area with epoxy, so after sifting/curing, I just brushed off the copper powder. In most of the bottom paint test panel photos I've seen in Practical Sailor, the unpainted areas between paints are covered with growth. If this isn't some sort of anomaly, then that would mean the areas of the dinghy that are scraped through regular use would have minimal growth.
I'll be updating the photobucket album as time goes by, and this Fall, I'll pull the dinghy and see what the bottom looks like. The best part of this, to me, is that as long as the copper doesn't slough off, the bottom paint should be permanent. Time will tell.
elspru likes this.
tanksalot is offline
post #2 of 4 Old 08-04-2012
Re: Homemade Permanent(?) Dinghy Paint
Why bottom paint a 175 lb dinghy ? Even a tender isn't in water all that much
WDS123 is offline
post #3 of 4 Old 08-05-2012
My dinghy is in water 24/7, April through November. The boat is on a mooring, the dinghy at a dock until I row out.
WanderingStar is offline
post #4 of 4 Old 08-05-2012
Get some old carpet and a roller - dinghy gets rolled onto dock, all nice and clean out of that nasty water
WDS123 is offline
Tags
bottom paint , copper , dinghy
Hypalon dinghy paint question TQA Gear & Maintenance 13 03-18-2011 08:44 AM
PVC Dinghy Paint CaptKermie Gear & Maintenance 0 03-10-2010 11:07 AM
Permanent Dinghy Engine Repair Solution LarryandSusanMacDonald Gear & Maintenance 8 12-03-2009 10:51 AM
Paint over permanent marker? or, can I draw on my deck? OhioTom Gear & Maintenance 5 07-18-2009 03:09 AM
Bottom paint for dinghy? prussell Cruising & Liveaboard Forum 1 07-24-2003 02:10 PM
