Junk in Deck Laminate - SailNet Community
 3Likes
  • 1 Post By hellosailor
  • 2 Post By fiberglass1
post #1 of 6 Old 08-05-2012 Thread Starter
Senior Moment Member
SloopJonB's Avatar
I have a question for the members with fiberglass laminating experience. I have been doing some spot recoring of the deck of my Columbia 43. The deck is partly plywood and partly balsa core. Yesterday I cut open a 6" square piece of the top skin where it sounded "punky" and found bone dry plywood core but also a piece of 12 gauge insulated wire laminated in between the core and the top skin. It extended past the opening in both directions so I don't know how long it is or where it goes. The reason the spot sounded punky was because a small loop of the wire had prevented the laminate from sticking tight to the core - it had left a small void where a pool of resin had gathered.
Has anyone ever run across this? Does anyone have any idea if it was done on purpose? I can't see how it could happen accidentally since the core had to be laid in the mould on top of it.
Any ideas?
SloopJonB is offline
post #2 of 6 Old 08-05-2012
Seņor Member
PorFin's Avatar
Re: Junk in Deck Laminate
Just a wild guess here, but maybe a ground wire in the bonding circuit?
PorFin is offline
post #3 of 6 Old 08-05-2012
Bonding wire, power to nav lights, whatever. It is not unusual, or at least was not unusual, for maufacturers to simply glass over wires that way instead of going to the expense of running a channel or wire mold.
If you don't have anything better, a lot of smartphones can use free software to work as metal/magnetic field detectors. You may be able to trace the wire that way. Or, cut it as see what dies.
Jgbrown likes this.
hellosailor is offline
post #4 of 6 Old 08-05-2012
Odd - wires would run on the underside of deck
Send a note to Columbia and ask
WDS123 is offline
post #5 of 6 Old 08-05-2012
Originally Posted by hellosailor View Post
or, cut it as see what dies.
I like the way you think.
Jgbrown is offline
post #6 of 6 Old 08-05-2012
fiberglass1's Avatar
Laminating rooms aint quite as sterile as operating rooms. We've found all kinds of contaminates in between layers of fiberglass. The most common is perspiration. Once, when peeling layers of gel coat and skimcoat (CSM) away from the structural layer (24 oz roving) we actually smelled that unmistakable odor of B.O.! Incredible, I know, but I looked into it and the boat was laminated in Florida in August. And the CSM/gel coat layer came away from the 24 oz roving without any great effort, so........
The funniest part about this is when potential buyers complain about seeing sunlight through the side of the hull. But after doing this for a long time I can tell you that when light doesn't pass through a laminate, something went wrong. Good and proper glass work is damn near clear. In fact, Monday morning, i'm returning a roll of 17.08 bi-ax because it doesn't laminate clear with epoxy, meaning it has a styrene soluble binder - no styrene in epoxy. WHOOPS!
Silvio and swedeish cedar like this.
fiberglass1 is offline
Repairing a hole in deck - use core material of laminate Summercamp Gear & Maintenance 2 09-02-2011 12:09 PM
Counter top laminate deniseO30 Gear & Maintenance 8 05-15-2011 12:33 PM
Pergo laminate QuickMick Gear & Maintenance 19 12-10-2010 05:00 PM
What do you get with laminate sails? MedSailor Racing 13 06-25-2008 07:19 AM
laminate cutting chuckg5 Gear & Maintenance 19 11-03-2006 12:32 PM
