What are these sailboat parts? - SailNet Community
post #1 of 7 Old 08-06-2012 Thread Starter
Hi,
I'm a non-sailboat person that has some sailboat parts I need identified. Our artificial reef association is cleaning a steel hulled sailboat to be used as an artificial reef. While cleaning the hull, I removed these parts for recycling. However, I have no idea what they are or the value of the parts. Any help would be appreciated.
The big yoke is off the rudder shaft, and is brass. The pulley wheels are brass, and the other things (maybe a "clutch"?) are stainless steel.
Thanks, Sea-r-cy
Sea-r-cy is offline
post #2 of 7 Old 08-06-2012
Re: What are these sailboat parts?
They are parts to the steering system.
The stainless "clutch" is a line stopper.
And thank you for your work.
ParadiseParrot is offline
post #3 of 7 Old 08-06-2012
two steering quadrants, three pulleys (probably for the steering system) and a double line clutch. Probably no economic value except to the one guy looking for that particular item.
ccriders is offline
post #4 of 7 Old 08-06-2012 Thread Starter
Thanks for the information. I'll add these to my "neat nautical items" collection. Sea-r-cy
Sea-r-cy is offline
post #5 of 7 Old 08-07-2012
Senior Moment Member
SloopJonB's Avatar
They're almost certainly bronze, not brass as well.
SloopJonB is offline
post #6 of 7 Old 08-07-2012
Old enough to know better
That is what I was going to say. and I agree if you found someone who needed it (unlikely) is the only way it would have any value to someone. Good luck.
miatapaul is offline
post #7 of 7 Old 08-07-2012
rugosa's Avatar
Good chance the quadrants and pulleys from Edson. One of the pulleys has cast A-450 on it. If you can find the casting numbers you could cross reference at Edson website. Also could be Buck Algonquin quadrants.
rugosa is offline
USED Sailboat Parts & Supplies in Annapolis ? backcreeksailor Gear & Maintenance 9 05-24-2012 02:45 PM
Found sailboat junkyard for parts k8edidski General Discussion (sailing related) 6 02-09-2012 12:48 PM
new member looking for parts for a Starcraft 16' Upstart sailboat wavysable44 Introduce Yourself 5 02-09-2012 10:16 AM
parts for apollo sailboat jaapovergaag General Discussion (sailing related) 0 08-15-2011 08:04 AM
Sailboat Trailer Parts question Perithead Gear & Maintenance 4 02-12-2010 02:54 PM
