Single burner Butane stove - SailNet Community
 1Likes
  • 1 Post By SchockT
post #1 of 7 Old 08-06-2012 Thread Starter
I am thinking of buying a Butane stove for use on my boat, any advice pro or con? It would be for occasional use while anchored out.
algee is offline
post #2 of 7 Old 08-06-2012
Learning the HARD way...
eherlihy's Avatar
Re: Single burner Butane stove
They work GREAT! - Much better than an alcohol stove!
eherlihy is offline
post #3 of 7 Old 08-06-2012
1975 Newport 28
jaschrumpf's Avatar
But you can't drink the butane in a pinch.
S/V Free Spirit
Monrovia, MD
jaschrumpf is offline
post #4 of 7 Old 08-06-2012
bristol299bob's Avatar
I'd be concerned about the safety of butaine. Butane is heavier than air and so it has the potential to settle in the boat. Does the stove have a thermo couple so that it wont vent butane if the flame gets blown out?
I am really happy with my Origo un-pressurized alcohol stove. I find it plenty hot/fast enough for anything that I have asked of it. And although I dont bake bread and cakes on board (yet) I do a lot of cooking and it's never been "too slow"
bristol299bob is offline
post #5 of 7 Old 08-06-2012
tdw
Super Fuzzy Moderator
tdw's Avatar
If you mean by that one of those single burner stoves with a built in gas bottle then you do need to take care. Keeping LPG/Butane inside a boat is not a good idea but if you do so then most definitely you'll need a gas sniffer in the bilge. Presuming that this is the sort of thing you are talking about ....
Me I wouldn't have one for quids. I'd reckon it would rust out in short order as well and lack of gimbals is not something I'd be happy with.
Even though I don't particularly like alcohol stoves myself in this case this is the way I'd go.
If however you are talking about a properly installed single burner gas stove with the gas battle out in the cockpit or in a gas locker then I'd prefer gas to alcohol.
edit - whoops , I've just realised that is a gas single burner. I intended to post an alcohol. They are pretty much identical in appearance.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #6 of 7 Old 08-07-2012
They're convenient to use in a pinch, and as started, use safety precautions. Here in MD the canisters are expensive and difficult to find.
wouldrathersail is offline
post #7 of 7 Old 08-07-2012
SchockT's Avatar
We have 2 butane stoves like the one pictured above, and they work great. They will boil water far faster than alcohol, and even propane. The canisters are easy to find, and fairly cheap. They pack away into a handy carrying case to be tucked away when not in use. We have had ours for several years with no sign of rust, but if they do rust out they are dirt cheap to replace. The concerns about gas accumulation, while not entirely unfounded, are overblown. The amount of butane in a canister is quite small, so if one does leak, the odds of creating an explosive mixture is pretty slim.
Overall they are a good low budget option if you don't need to cook while under way. It is nice to be able to cook in the cockpit, on the dock, on the beach, or anywhere else you feel like!
eherlihy likes this.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
Butane stove dvuyxx Gear & Maintenance 10 05-01-2012 07:19 AM
single Mom, single hander, single paycheck. GreenBoat Boat Review and Purchase Forum 61 11-23-2011 08:29 PM
cleaning an alcohol stove burner? peterchech Gear & Maintenance 4 11-01-2011 01:33 PM
2 or 3 burner stove and "why would I want a microwave...?" F15EWSO Cruising & Liveaboard Forum 26 06-12-2011 09:42 AM
Cheap Butane stove fuel cans!!! MacGyverRI Provisioning 14 04-14-2011 09:49 AM
