  #31 (permalink)
Old 07-11-2011
windward54 is on a distinguished road
Sounds like you have an antenna issue. The ground you use wouldn't have any effect on the receive. Couple of items to check. Make sure you hooked the antenna to the correct connector. The 802 has two connectors on the back, one for antenna and one for DSC. Both look the same. If that is correct, start checking your antenna connections.
ham radio ground bernie-t Gear & Maintenance 3 09-11-2008 06:37 AM
Where to Ground to?? elvisnpriscilla Gear & Maintenance 6 03-05-2003 09:59 PM
Shore power problem! Burned ground wire at main breaker JohnDrake Gear & Maintenance 2 08-20-2002 05:08 AM
Any Yeoman Sport XL users out there? jamier General Discussion (sailing related) 1 08-02-2002 07:33 AM
Ground for AC System fesivo Gear & Maintenance 1 01-23-2001 09:47 PM
