Replacement of vinyl lifelines - Page 3 - SailNet Community
 12Likes
post #21 of 43 Old 08-10-2012
aeventyr60's Avatar
Re: Replacement of vinyl lifelines
Just out of curiosity, does anyone here have personal experience of anyone going over the side due to the failure of the wire in vinyl coated lifelines?
Must be in the rogue wave,fin keel,this anchor,yade, yade bigger is better conspiracy...
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #22 of 43 Old 08-10-2012
I'm sure I will replace my lifeline with bare wire, when I get to it. Them's the rules.......
However, I find lifelines to be fairly useless safety devices anyway. We stay in the cockpit and/or clip in.
Lifelines are great clothes lines and rail meat organizers.
msmith10 likes this.
Jeanneau 54DS
Minnewaska is offline
post #23 of 43 Old 08-10-2012
Originally Posted by aeventyr60 View Post
Yo Knotty,
What's your take on using Dynema or other synthetic line for lifeline applications?
I have no problem with them. If I could afford it, that's probably what I would choose. The UV issue is probably the main problem, along with chafe, but that's just like the corrosion problem with wire. Replace them when they need it and you don't have to worry.
I agree that lifelines, no matter what they are made from, should never be expected to keep you on the boat. That's what tethers and jacklines are for.
I have heard of people falling off their boats because of lifeline failure. But not because the wire broke. The cases I've heard about were caused because a clevis pin fell out or a gate eye came unscrewed or things like that.
Usually it happens to guys who are leaning against the lifelines to relieve themselves without having an arm looped around a shroud.
knothead is offline
post #24 of 43 Old 08-10-2012
Senior Moment Member
SloopJonB's Avatar
Exactly. The coated lifeline "issue" looks to me to be very much like all those other "issues" where a minor theoretical benefit becomes conventional wisdom and escalates over time into a sort of hysteria, particularly amongst those with no personal experience in the subject.
Knotties a RIGGER folks - he knows more about this stuff then most of the rest of us combined and should be listened to over the siren call of all those "experts" who opinions are based on "something they heard".
I read a stat years ago wherein it was stated that something on the order of 70% of all male drowning victims had their flies open.
SloopJonB is offline
post #25 of 43 Old 08-10-2012
tommays's Avatar
Three guys went swimming this spring in the AYC series because in the haste to be ready a cotter pin was left out of the something
Now the really stupid part starts when your sailing in 50 degree water + 20 knot winds and NOBODY was using a PDF
My friend was on and Oakcliff Boat that was one of the boats that fished them out within < 2 minutes and they were already seconds form drowning
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #26 of 43 Old 08-10-2012
Lightbulb Re: Replacement of vinyl lifelines
In the last decade, two different boats in our little moorage have had lifelines break... at the dock of all places. In each case they were over 15 years old.
No one was injured and someone casually grabbed onto onto a lne and it... broke.
One was a ss threaded togle screw that was found to have a slow-increasing fracture in the metal and the other was a wire that broke just inside the swage (the classic place).
It's been longer, but I was there when a fellow leaned on his forward lifeline and it broke and he fell in backwards. He got lucky and did not bang into anything with his head... only got wet.
Lots of rationalization about life line durability... much like standing rig maintenance attitudes.
Treat it like any other Preventative Maintenance issue on your boat. Waiting for a failure to produce injury/death and much larger expense after the fact is imprudent, at the least, and really more like negligence.
Whether you replace with bare ss, hi tech line, or the ss with a thin (and attractive!) vinyl cover, do so regularly.
olson34 is offline
The Following User Says Thank You to olson34 For This Useful Post:
jgeissinger (11-22-2013)
post #27 of 43 Old 08-10-2012
davidpm's Avatar
That's why it's rather important to know how old stuff on your boat is. Standing rigging, chainplates, lifelines etc.
At what age do you recommend replacing each of the above?
davidpm is offline
post #28 of 43 Old 08-10-2012
That really depends on a number of factors. Most important probably being locale and whether or not the boat is sailed on salt water.
As was mentioned earlier in this thread, great lakes or other freshwater boats don't have nearly the corrosion problems that salt water boats have. Also, the more tropical the climate, the bigger problem corrosion seems to be.
But also, maintenance plays a part. If chainplates have been leaking, that would certainly accelerate their degradation and cause them to need replacing earlier than one's that have been kept dry.
If stuff isn't rinsed off after being bathed in salt water, it's going to corrode quicker.
I'm speaking mainly of cruising boats here too. My partner, when he was racing, would replace his rod rigging every five years. Those racer's can really stress a rig.
Whereas I've seen rod rigging on cruising boats that was twenty years old around here and that still looked good. (I still think that's way too old and told them so).
So, to answer your question directly. In this area, Tampa Bay, I recommend thorough and regular standing rigging inspections starting at 10 years and replacing standing rigging between 12 and 15 years regardless of what the inspection reveals. The same for stainless steel lifelines.
Chainplates are a trickier proposition. I usually always recommend inspection at the time of re-rigging, but the thing is that they need to be removed in order to inspect them properly. And if you go to the trouble to remove them, then in my opinion it's a bit silly to put the old one's back even when they look okay. They usually aren't all that expensive to fabricate so you might as well replace them and the bolts and sleep better at night.
Hope that helps.
knothead is offline
post #29 of 43 Old 08-10-2012
SloopJonB's Avatar
And the unbroken wire continued dangling over the side I presume?
post #30 of 43 Old 08-10-2012
I have seen two cases where the wire itself broke, one on a set of lifelines that was ancient, no idea how old, but the boat was a 60's era cruiser, and may have been original. The other was on a J-35 with about 5 year old lifelines. The wire failed about 1" inside the coating from the swag. In neither case was anyone injured, but on the J, 8 people fell in while hiking.
I am still not sure where the idea is that dyneema is more expensive than wire comes from. A reasonable installation is some amsteel blue, and a few sailmakers thimbles. There is no hardware to buy, and other than some work to soften stantion holes (where needed) almost no labor.
For my Beneteau there are 8 splices, that took about an hour to do, $5 in thimbles, and 100' of 1/4" line. That's it, the stantions were already soft enough to take the line. Assuming you paid full retail, that would be $145 in parts, and an hour of riggers time, so even at $100/hr you are still looking at less than $250 total.
Now I didn't use stainless gates, just lashings, but even if you do, they are the same Johnson gates for stainless fittings, but use a different screw post that are about $8. So perhaps you will spend a little more on the hardware, but the difference in the cost of wire vs rope should easily make that up.
As for chainplates, and rigging... When I was working as a rigger, we recomended inspection at 8 years, and every year after that (these were the manufacturers recomendations). Like Steve, I feel that chainplates are rarely worth reinstalling. The issue is that by the time you get them out, pay someone for the inspection (they must be dye or x-ray tested, visual inspection is bad practice), replace any cracked one, and then reinstall them, you likely could have just replaced them for the same amount of money.
Greg
Stumble is online now
I-28 Vinyl Headliner Replacement gknott Islander 27 05-04-2015 03:44 AM
Vinyl Fabric Replacement mm2187 Gear & Maintenance 6 02-21-2012 09:11 PM
Lifelines: Bare Wire vs. Vinyl Coated Debate Sabreman Gear & Maintenance 19 12-25-2008 11:50 AM
Lifelines - need help Suz Gear & Maintenance 11 07-07-2003 05:20 AM
Lifelines wgfischer Gear & Maintenance 8 06-17-2003 11:39 AM
