Replacement of vinyl lifelines - Page 5 - SailNet Community
 12Likes
post #41 of 43 Old 08-13-2012
Re: Replacement of vinyl lifelines
Not quite sure what you mean there unless it should read injuries of work which are the units I use to measure the size of my personal projects.
Lol stupid iPad autocorrect, should have been minutes.
Itgoshen,
Those rust rings through the coating are where the wire underneath have rusted so bad the rust is weeping out of the covering. That is an absolute indicator of impending failure. Generally they look fine, but those few spots condem the entire system.
Greg
Stumble is offline
post #42 of 43 Old 09-19-2012
Nope, you have ugly railings. I'll take my chances with lifelines.
Taking style over substance priorities to sea can get you killed. There was time when any lifelines at all were considered ugly. Killed a lot of sailors. Wisdom eventually began to sink thru the ivory.
I can think of nothing uglier than seeing any boat sailing away without me, while I tread water, admiring her "Yachtie" but inadequate lifelines.
I could never see beauty in dainty, fragile, yachtieness, only foolishness.
I'm no longer foolish enough to buy such naive priorities.
Brent Swain is offline
post #43 of 43 Old 09-20-2012 Thread Starter
First String
Dangit. maybe I "will" change them.
I dont want to die!!!!
ltgoshen is offline
I-28 Vinyl Headliner Replacement gknott Islander 27 05-04-2015 04:44 AM
Vinyl Fabric Replacement mm2187 Gear & Maintenance 6 02-21-2012 10:11 PM
Lifelines: Bare Wire vs. Vinyl Coated Debate Sabreman Gear & Maintenance 19 12-25-2008 12:50 PM
Lifelines - need help Suz Gear & Maintenance 11 07-07-2003 06:20 AM
Lifelines wgfischer Gear & Maintenance 8 06-17-2003 12:39 PM
