Too much zinc? - Page 3 - SailNet Community
 9Likes
post #21 of 25 Old 08-17-2012
Senior Cruiser
sea_hunter's Avatar
I had a tool once, but too much zinc made it corrode away.
sea_hunter is offline
post #22 of 25 Old 08-18-2012
Senior Slacker
SlowButSteady's Avatar
Re: Too much zinc?
Are you sure you just didn't lubricate it often enough?
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #23 of 25 Old 08-19-2012 Thread Starter
L124C's Avatar
So...it's come to this, has it?
No....lack of use eliminates the need for lubrication.
It appears this thread has run it's course. I'm off to line my hull with Zinc!
L124C is offline
post #24 of 25 Old 08-19-2012
Re: The debate goes on!
Originally Posted by L124C View Post
They said that you can only have too much Zinc on wooden boats because it effects the binder in the wood (who would have thunk!), as discussed on their website...
....any opinions on the gizmo Boatzincs.com is selling to measure the currents in the water using a multi meter Corrosion Reference Electrode. I've tested the water for current using Don Casey's methods but didn't know that tool existed.
The gizmo you refer to is a silver/silver-chloride electrode, which is used to measure the stray currents affecting your boat. I've used them. They work well, but they are a bit pricey. If you are experiencing abnormal wear on your zincs, or have issues with blisters on metal hulls, or problems with any of the metal components underwater,
-and-
you understand the concepts involved with electrical currents, galvanic corrosion and electrolysis, then you may find the Ag/AgCL probe a benefit.
It's very useful in tracking down an elusive bonding wire or help confirm your system is well protected.
Kg
L124C likes this.
Kajungizmo is offline
post #25 of 25 Old 08-23-2012
Re: Too much zinc?
Thanks for the correction of a couple of hundred years. Remembered the principle, not the year. Thanks again for the correction!!!
rackham the red is offline
How much zinc is enough? Petar Gear & Maintenance 36 10-17-2011 09:22 PM
More Zinc Please... DrB Gear & Maintenance 9 11-13-2008 01:22 PM
