Dinghy outboard rec. - SailNet Community
post #1 of 15 Old 08-09-2012 Thread Starter
utchuckd's Avatar
What's the recommended size for a dinghy outboard? It's an 8-ish ft. inflatable.
utchuckd is offline
post #2 of 15 Old 08-09-2012
Re: Dinghy outboard rec.
Depends on a whole lot of things, load, soft or hard bottom, manufacturers limitation, & so on. We had an 8 foot soft bottom inflatable with a 2HP Honda on it. It would beat against a chop and current with two people on board just fine, not real fast but a whole lot better than rowing. Nice thing was that it ran perfectly for many years and only weiged 27 pounds.
Paul T
dabnis is offline
post #3 of 15 Old 08-10-2012
That info is on the manufacturers id plate on all boats even blow up ones.
bandaidmd is offline
post #4 of 15 Old 08-10-2012
Unless not designed to have one at all.
Jeanneau 54DS
Minnewaska is offline
post #5 of 15 Old 08-10-2012
potentially a true statement but if that's the case I think it will be tough to get registration numbers and in most locales motorized means registered.
post #6 of 15 Old 08-10-2012
Unless you have a special need and or special equipment, I concur with Dabnis; weight is a major consideration if you're going to be hauling it up and down from a stern rail location to the dinghy. His Honda 2 Hp 27 pound is probably perfect for what most people do.
In retrospect, I wish I had gone smaller and lighter for my 8 ft inflatable.
tempest is offline
post #7 of 15 Old 08-10-2012
I meant their would be no max hp info on the data plate, if the inflatable was not designed for a motor.
Jeanneau 54DS
post #8 of 15 Old 08-11-2012
If you are still allowed to buy 2 strokes in your part of the world, a 3.3 hp Mercury has a neutral gear, goes really well on an 8ft rubber boat and is still light enough to hoist over the rail.
And being a 2 stroke it won't need any maintenance - well mine doesn't get any and it is happy enough even living mostly in salt water. The only fresh water it sees is when it rains or when it's running in a river. Starts first pull every time.
arvicola-amphibius is offline
post #9 of 15 Old 08-11-2012
I got a Yamaha 2.5 that is pretty reliable and plenty light, does fine on my soft bottomed dinghy. I have a friend who uses an electric trolling motor, works for him and much cheaper and more reliable than gas. So long as u have a way of keeping the battery charged.
peterchech is offline
post #10 of 15 Old 08-13-2012
My 8ft 6" Achilles will take up to 6hp. It seems that you either need the full 6hp to get it to plane, or give up on planing and go for 2 to 3hp and have a lightweight engine that's easy to handle.
I did the latter and got a Suzuki 2.5 4 stroke. Can't say I like it very much. I had a Tohatsu 3.5 4 stroke on my last boat, and it was much better.
MarkSF is offline
Dinghy Outboard rjcaudle Boat Review and Purchase Forum 3 09-07-2011 03:55 PM
Outboard for dinghy Windward742 General Discussion (sailing related) 3 06-26-2011 06:25 PM
dinghy outboard 2 or 3.5 hp huguley3 Gear & Maintenance 22 05-11-2009 07:28 PM
Dinghy outboard jasonr575 Gear & Maintenance 22 01-31-2008 07:13 PM
Dinghy Outboard labatt Gear & Maintenance 16 07-22-2007 08:28 PM
