Old 08-09-2012
i_amcdn is on a distinguished road
Send a message via ICQ to i_amcdn Send a message via MSN to i_amcdn Send a message via Yahoo to i_amcdn
Worn through to gelcoat?
Ok I will fess up. I can spell "gelcoat" but I have never see it....at least as far as I know.
In the attached pic of our boat stripe (red) you can see that some of the red has flaked off and there is a VERY smooth light green material showing through.
I am presuming that this is the gelcoat.
What is best way to repair?
The white part looks like it was painted, rolled but not tipped as it has lots of bumps and what looks like unpopped bubbles. I am going to sand it smooth and repaint....or at least that is the plan. I may run out of warm days this fall before I get that far in which case I will focus on the red stripe area only and do the white next year.
Thanks
You may post attachments
You may edit your posts
Worn Prop Shaft rhsanborn Gear & Maintenance 23 07-16-2012 03:51 PM
Non-skid worn down to fiberglass sfbaysailor2012 Gear & Maintenance 11 04-03-2012 09:41 AM
Rudder bushing worn out (F-24 Mk1) brak Gear & Maintenance 0 11-12-2010 06:35 PM
Worn Companionway Cover harbin2 Islander 5 10-07-2009 07:51 PM
A Worn Shaft Log Tom Wood Gear and Maintenance Articles 0 10-06-1999 08:00 PM
SEO by vBSEO 3.6.1
