With all due respect to Bruce, there are many simple and cheap ways to isolate your boat galvanically. I dont claim that this is an end-all, be-all list but its a good start:
1. Depending on the amount of room you have 1-2 zincs on your prop shaft. They must make an electrical connection to the shaft so dont
paint the shaft in the area where you put them on and dont
paint the zincs themselves.
2. Engine Zincs. Depending on the make and model of the engine you may have one or more zinc pencils that need to be 50% or more.
3. Drivesaver device. Its primary purpose is to absorb vibration and shock but it also prevents electrolysis of your engine by blocking the current from the water from ever reaching your engine.
4. Galvanic isolator. If you keep your boat on a dock and are plugged into shore power this is a must; otherwise your boat can turn into an electrolysis magnet from the stray currents.
5. Have not tried this one myself but, using a length of copper wire connect all of your sources of underwater metal (ie seacocks) and then attach to that one of those sacrificial "grouper" (basically just a zinc but its shaped into a fish for some reason) and throw said grouper into the water.
One of the major magazines had an article on this very subject recently. You might want to try a google search.
MJH
