Pole Mounts - SailNet Community
post #1 of 5 Old 08-10-2012 Thread Starter
wduncan50's Avatar
Pole Mounts
The PO of my boat mounted the solar panel off of the stern with poles clamped to the aft pulpit stanchion posts with spacers between. I have been trying to find a better mounting soultion.
I would like 1" to 1" mounting clamps of some sort but can't find anything like this. Does anyone know were I can find them?
Attached is a picture of the existing mounts. Hope you can see them.
Will Duncan
wduncan50 is offline
post #2 of 5 Old 08-10-2012
Re: Pole Mounts
Hmmm, could make em out of G10. Maybe with a bolt between the two 1" cutouts to hold em together.
Frogwatch is offline
post #3 of 5 Old 08-10-2012
A New Adventurer
funjohnson's Avatar
Re: Pole Mounts
Cant see the photo well, but how about one of these:
Clamp-On Jaw Slide
to one of these:
Top Slide Jaw Slide
1989 Sabre 34II Targa
mjsailing.com
funjohnson is offline
post #4 of 5 Old 08-10-2012
Re: Pole Mounts
What exactly do you have a problem with? It doesn't look to bad in the photos. If you want a better spacer you could make them using a 1" hole saw to cut 1" square or round tubing in a drill press so that you have two half rounds on a short piece if tubing. Then if you don't like hose clamps, you could use Band-It or Punch-lok style band clamps which are permanent and don't have a screw or band tail sticking out.
Gary H. Lucas
GaryHLucas is offline
post #5 of 5 Old 08-11-2012
tommays's Avatar
Re: Pole Mounts
The mainsail mount works well for me BUT with the amount of canvas you have UP i think it needs to stay in its current home
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
whisker pole or spinnaker pole ltgoshen General Discussion (sailing related) 11 06-20-2012 01:38 PM
Using spinnaker pole to pole out jib when sailing downwind... sweetdreamyamaha Seamanship & Navigation 5 09-08-2010 10:39 AM
Using a spinnaker pole instead of a whisker pole aphil138 Gear & Maintenance 14 03-31-2008 02:51 PM
Wanted a Whisker Pole and a Spinnaker Pole matthiesen Gear & Maintenance 0 02-22-2008 02:10 PM
North Pole. Pete Goss puts Playing for Success Charity in Pole position @ BYM Sailing News NewsReader News Feeds 0 04-20-2006 04:15 AM
