Freshen up bottom paint. What's fair $$$ - SailNet Community
 1Likes
  • 1 Post By CalebD
post #1 of 6 Old 08-10-2012 Thread Starter
I'm running an ablative bottom paint that has worn and flaked free from the water line yet is still reasonably intact over the rest of the hull.
I had the boat hauled and the yard is going to sand down the areas of flaking paint and prime with barrier coat... leave the more solid areas alone... and then recoat the whole bottom with 2 coats of ablative again. They want about 40 bucks a foot to do that. Seems high to me.
What are your guys thoughts about only spot painting with the barrier coat in the regions that the original paint flaked off. Seems you would be feathering barrier coat OVER old ablative paint?
I would think $40 a foot should cover COMPLETE sand down and barrier coat and recoat with 2 layers?
Any advice would be appreciated!
SiXeVeN is offline
post #2 of 6 Old 08-10-2012
Re: Freshen up bottom paint. What's fair $$$
That's high. Unless your boat is a big dog, then $15 per foot for the first coat with a very light sand and $5 per foot for the second would get you fully tuned up. (plus the paint)
I mean, we're talking labor they can practically pay high school kids to do. No experience necessary.
Jeanneau 54DS
Minnewaska is offline
post #3 of 6 Old 08-10-2012
Senior Cruiser
sea_hunter's Avatar
I just did our 32'r and it cost $150US for one coat in materials; not quite $5 per foot and I supplied the labour. Ablative paints run about $100 per gallon on the low end. You can figure it out from there.
sea_hunter is offline
post #4 of 6 Old 08-11-2012
Tartan 27' owner
CalebD's Avatar
The idea of spot barrier coating sounds like a non-starter to me. The barrier coating should be applied over the entire under water surface and then painted with anti-fouling paint. Why do a half way measure of barrier coating some of the hull? The barrier coat is supposed to provide just that; a barrier. If it is not continuous then it is not a barrier at all.
$40/ft sounds quite high to me. I buy 1 gallon each spring and put it on myself with the materials costing < $150 (cheap paint = WM CPP). 1 gallon of paint gives me nearly 2 coats on my 27' boat. I provide the labor and not only did I graduate from high school but have a kolledge degree.
AncientTech likes this.
Everybody has one:
CalebD is offline
post #5 of 6 Old 08-12-2012
JimsCAL's Avatar
I agree that priming with barrier coat doesn't seem to make sense. Either take the bottom down completely and apply barrier coat, or just sand and/or scrape the loose areas and apply bottom paint. Price of $40/ft seems high, but it will probably come down if you tell them to forget the priming with barrier coat. If price includes paint and other materials, it may not be all that high. Note that competely stripping the bottom will cost much more than $40/ft.
As has been noted, if you can do the work yourself, you are looking at saving quite a bit.
JimsCAL is online now
post #6 of 6 Old 08-12-2012
Senior Cruiser
sea_hunter's Avatar
Actually, touching up the primer on a previously barrier coated hull is how it's done. Usually applied to leading edges and places where the ablative paint has worn to the barrier. If the hull isn't barrier coated it's just a waste of material.
Don Casey: Paint Waterline Stripe with Bottom Paint asdf38 Gear & Maintenance 23 03-05-2016 06:50 PM
Bottom paint prep, chipped paint josrulz Gear & Maintenance 16 02-14-2010 08:24 PM
Bottom Paint Divet(s) - How to fill/fair backcreeksailor Gear & Maintenance 4 04-09-2009 05:53 PM
bottom paint banshee Gear & Maintenance 16 04-02-2007 04:43 PM
Bottom Paint offline2004 Gear & Maintenance 8 03-06-2006 11:42 PM
