I just went out to Yachtworld to try to find some pics of the cockpit of an Aloa 34. Found some and they didn't seem obstructed. Was something modified or maybe different years had different layouts.
That pic does not look like mine.
I have not been able to find a good pic of it so I will have to take one.
However the railing post does interfered and it seems unwise to remove it.
I don't recall ever seeing a boat leave the factory with winches and handles that could not turn so I have to think something is NOT in its original location
As I already said, I don't think they are made any longer. Look in online marine consignment shops. However, you may need a different solution. Even if you find one, what will you do if you lose it or drop it overboard or the ratchet mechanism fails.
There are threads here for cordless right angle drills with a winch adapter. That might be a solution for you.
It is correct that they are not made anymore. I sold one a year ago on ebay. As above, watch consignment shops or ebay- they do show up once in a while. South Coast made one at one time. Try calling Minneys.
Not sure of a retail source off hand, but have seen several references to 12" winch handles over the years. Perhaps a bit of extra leverage would help?
FWIW dept: we have a T-handle 10" that is oodles better than the standard handle. At least one can get more upper body strength into the rotation....
Note B: You might also re-think the location and angle of your primaries. Almost all production boats have their winch bases angled outward due to the overall angle of the top of the combing. This made the original tooling a bit less expensive, looks proper when viewed at the boat show, but leaves the grinders having to reach outward, away from their core strength.
It's fine for a tall and muscular 20-something guy, but terrible for everyone else. After some diagraming and a mockup, we added some risers under ours and changed the angle to bring the winches level.
Now they are much much (much!) easier to use.
If you buy a ratcheting drive from a hardware store for this you will need to baby it to prevent corrosion inside the mechanism. It will require frequent flushing and liberal treatment with a corrosion inhibitor. Or just replace it frequently. You can pick up used half inch ratchet drives for a few bucks and carry a whole toolbox full of them for what you will pay for one ratcheting winch handle.
Machine shops are such a wonderful invention. Probably for less than one could buy a ratcheting winch handle, a machine shop could turn a ratchet drive into one.
How much is the constraint? Our Contessa 26 has the winches too close to the stanchions ... for a 10" winch handle. The 8" is fine. We decided to stay with the 10" handle and ratchet it on our single-speed winches as the extra leverage and handle feels better.
Instead of a ratchet, would a shorter handle work in your case?
Also try Bacon's in Annapolis. They have a lot of consignment gear for sail. If you can fine one it will be pricey because they were never common and there is quite a bit of demand. I bought a used one some years ago and it was much more than a new, standard handle. I would not worry about dropping it over the side - with the price and difficulty finding one you will be extra careful.
Wouldn't a closed end ratcheting wrench attach readily to the other end of the Winchbit?
If so, yes, I'd stick it in the end of the wrench and epoxy it there for a cheap solution.
http://www.northerntool.com/shop/tools/product_200495415_200495415?cm_mmc=Google-pla-_-Hand%20Tools-_-Wrenches-_-19819&ci_sku=19819&ci_gpa=pla&ci_kw={keyword}
Got the winch bit and it worked well with socket wrench. A 12mm socket is actually a better fit for the drive end of the winch bit.
My choice of epoxy to set the Winchbit into a socket may not work for long. Used the PC-7 black / grey epoxy paste. Don't know if it was too old and didn't set up well but the bit is starting to work lose after a few uses.
Might try the somewhat flexible epoxy West Systems has or maybe just get it welded.
As others have noted, I would worry about the ratchet mechanism rusting in due time. Sears Craftsman make some mew ratcheting wrenches that will fit multiple patterns. When they do rust you simply take it back to Sears and they replace it under their lifetime guarantee.
I had a beautiful Stainless Craftsman ratchet wrench. Did not realize I dropped it in the driveway one year before the first snow fall. It got plowed into the snow mound at the bottom of the hill. It sat there all winter with driveway salt all winter till the summer thaw. It worked fine for a few more years till the dentant ball came out. I took it back to Sears, and they did not make it anymore, and they gave me the best available. Wish I had them send it back for repair, but needed it for a job that weekend.
Fit 2 speed winches and use a longer winch handle for when it starts to get heavy
Related Threads
1.7M posts
173.8K members
Since 1990
