Cost savings on a Dinghy lift harness/tackle kit - SailNet Community
post #1 of 2 Old 08-13-2012 Thread Starter
F15EWSO's Avatar
As I consider the cost of raising the dinghy the blocks can get very expensive. As most of these are designed for holding loads on sails etc they are a bit of overkill in design but the multiple pulleys are needed to ease the weight of the load coming up. In addition a heavier line is easier on the hands but harder on the pocketbook.
Has anyone seen or used an unconventional source or design that is still marine proof and resists the salt water environment. I tried REI and the climbing route but no success there as their equipment is for a different purpose.
THanks in advance
F15E_WSO + 1
Deale Md, to Caribbean Oct 2012-Aug 2013
Boat Type Irwin 43 Mk III Center Cockpit--Sold it
Boat Yr, 1989
Boat Length 43'
F15EWSO is offline
post #2 of 2 Old 08-15-2012
Re: Cost savings on a Dinghy lift harness/tackle kit
Try surplus or salvage blocks from rigging, marine consignment. My dinghy only weighs 100lbs, so a simple block and tackle will do.
WanderingStar is offline
Outboard lift davit for dinghy motor on 27' cal lans0012 Gear & Maintenance 8 08-19-2011 11:01 PM
Boat lift cost worth the saved maintenance? bonedoc Gear & Maintenance 5 11-01-2009 10:16 PM
rock climbing harness as a sailing harness johnnyandjebus Gear & Maintenance 7 09-22-2009 05:46 PM
