Replacing old VHF - SailNet Community
post #1 of 20 Old 08-13-2012 Thread Starter
Replacing old VHF
The display on my old (14+ years) Standard horizon Intrepid has failed and i am replacing it. the technology has changed a lot and i am looking at the Standard Horizon Matrix 2150 with AIS. also the Ram 3 remote mic since it would give me longer range and better reception over the hand held i use in the cockpit now. i like the fact that this unit uses the current VHF anteana and you do not have to install a second anteana and is also a hailer. to me it seems to be a lot of bang for the buck. i was very happy with the old VHF and to me they seem to be of good quality.
Does anyone have experiance with this VHF. any feedback, Pros and Cons would be appreciated. also recomendations on other brands that are comparable and you feel may be better.
Thanks
Bill
sailrmon is offline
post #2 of 20 Old 08-13-2012
Re: Replacing old VHF
Installed one last September. Crossed my fingers in planning the installation the installation because the boat was in Gibraltar. Turned out the install was easy and the NMEA 0183 connection to an old Magellan GPS worked on the first try.
The quality of the transceiver was excellant. The AIS portion was a godsend sailing to the Canaries - Atlantic crossing - St. Thomas and finally Miami.
Mike
SOVT is offline
post #3 of 20 Old 08-13-2012
Senior Cruiser
sea_hunter's Avatar
Good choice. We bought ours a few months back and connected it to our chartplotter. Works great and going to buy a second for the lower station. Check out sale pricing as everyone's asking $399.99.
sea_hunter is offline
post #4 of 20 Old 08-13-2012
1979 C&C 30 MK1
flyingjib's Avatar
June issue of Practical Sailor reviewed mid-range VHF radios. As always very informative:
Practical Sailor - June 2012
flyingjib is offline
post #5 of 20 Old 08-13-2012
Cruiser2B's Avatar
I bought the older verision 2100 new a few months ago for $219, leftovers i guess. I am not sure what the differences are, but this unit works well with my Garmin 120. Good luck!
My two lovely ladies!!
USCG 100T Near Coast Master with 100T Inland Sail Endorsement
Cruiser2B is offline
post #6 of 20 Old 08-14-2012
BIll, SH still makes great gear but if your existing antenna has been up 14 years?
It is time to replace the coax and either inspect or replace the antenna. Even if there is no water damage, the weight of gravity pulling down on coax compresses the insulating layer, which changes the performance of the cable, so it degrades over time. Fourteen years? Time to do some checking, at least.
hellosailor is offline
post #7 of 20 Old 08-14-2012
The 2150 works better than the 2100 (or, rather, works at all) with some chartplotters that only have one NMEA 0183 interface.
There's a document here explaining the differences :
http://www.standardhorizon.com/downl...pplication/pdf
I installed the 2150 and have it talking to my Lowrance HDS-5M chartplotter. Couldn't be happier with it. Reception is excellent, quite an improvement on my previous 1150.
I'd also recommend SH over other brands, on the basis of their customer service, which has been great.
MarkSF is offline
post #8 of 20 Old 08-14-2012
Like he said!
MarkSF is offline
post #9 of 20 Old 08-14-2012
Call me Ishmael
blowinstink's Avatar
Love the 2150 I bought last year. After a couple of offshore runs with it, I have no complaints. However, if I were going to start from scratch now, I might buy an AIS transceiver: I like the AIS so much that I would like to be broadcasting a signal as well. Throw that in the hopper . . . definitely the Matrix is easy and way better than no AIS capability at all.
blowinstink is offline
post #10 of 20 Old 08-14-2012
Battered and Bruised
Silvio's Avatar
Been using my 2150 for about a yer also and love it. I agree with Blowinstink's sentiments. I like having AIS so much that I feel like I should be broadcasting a signal as well as receiving them.
No regrets on the SH 2150, easy install, easy to hook up to the chart plotter, and simple RAM installation.
SV S.S.R.I
It's my happy pill
Silvio is offline
Replacing Windows seb5thman Gear & Maintenance 5 02-12-2010 07:02 AM
Replacing windows Dick Pluta Gear & Maintenance 30 02-03-2010 05:58 PM
Replacing Windows.. leland515 SailNet FAQ 3 10-18-2009 09:05 PM
Replacing old spreaders Dirtboy Morgan 3 09-28-2009 04:52 PM
Replacing Impeller ccriders Gear & Maintenance 25 06-29-2008 07:12 PM
