Fresh Water Heads - SailNet Community
 1Likes
post #1 of 16 Old 08-13-2012 Thread Starter
tdw
Super Fuzzy Moderator
tdw's Avatar
Fresh Water Heads
Over in the "Everyone Needs a Bigger Boat" thread Doug S mentioned that their new acquisition has fresh water flushing in the heads.
Why ? Why in the name of all that is holy would anyone choose to have fresh water heads ? (Emphasis on CHOOSE)
Now I've seen a couple of folk here discussing FWH and one of the boats we considered last year had them (it was probably the ultimate deal killer for us) but no one has ever given me a half way decent reason as to why one would choose to waste all that precious fresh water.
Thoughts ?
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #2 of 16 Old 08-14-2012
blt2ski's Avatar
Re: Fresh Water Heads
One of the ONLY reasons I can think of, if in salt water, the salty water will ruin the hoses quicker than if they only have fresh water in them. Along with if you do not use your head a lot, say only in the boat once a month. salt water stinks sooner than fresh.
At the end of the day, not sure it really matters much. Altho I do keep a 1 gal ug with FW in it, so as to not have the issue(s) I mentioned above.
marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #3 of 16 Old 08-14-2012
HANUMAN
RobGallagher's Avatar
Fresh water flushing killed the stank in my head. Your mileage may vary, but, one thing is for sure, sea water is filled with micro organisms that stink like low tide when they die.
davidpm likes this.
RobGallagher is offline
post #4 of 16 Old 08-14-2012 Thread Starter
tdw
tdw's Avatar
Ok, I agree re the micro organisms and the pong. With salt water flush the first minute or so of flushing when you first get on board after a break is a bit off. Marty has a solution and its one we've even used though you cannot rid yourself of the water in line from the inlet seacock so that first flush will still be whiffy unless (shock horror) you leave the seacock open. Not on our boat you don't and if all you do is pump a couple of gallons through the system with the toilet seat down the whiff is a very passing problem.
The fact still remains that if your flush is all fresh water then you are flushing overboard possibly your most precious resource and one that is difficult to replenish if you are not tied to a dock. Dammit all we use up enough fresh water at it is without flushing the stuff through the dumpster.
So no, I don't think the pong is a good enough reason to go fresh flush and Marty we replaced all the head hoses on Raven when we bought her and six years later they were still good, probably still are today. On the new girl they well predate us and I am seeing no reason to replace them as yet.
Thanks for your replies guys, but would you go fresh in a new boat ?
― Terry Pratchett.
tdw is offline
post #5 of 16 Old 08-14-2012
Wandering Aimlessly
PBzeer's Avatar
I wouldn't go with FW. While I can understand the thinking, I can't find sufficient value, to me, in the concept to adopt it, as it's not something that's been an issue for me (the smell).
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
PBzeer is offline
post #6 of 16 Old 08-14-2012
If constant smell is an issue I suggest you might have a SYSTEM issue.
The thought of a malfunctioning check valve getting stuck and getting sewage in the fresh water supply give me the willies.
ParadiseParrot is offline
post #7 of 16 Old 08-14-2012
We are usually only away from our boat for three days at a a time, but that is enough to get the seawater in the intake hose to rot out and smell very bad on that first flush. Let's face it, that is a very bad smell, not just a little wiffy. When we remain aboard, it is not a problem at all. However, since I'm a big advocate of flushing great amounts of clean water to clear the waste lines, I would not want to use that much fresh water.
If I could upgrade to a vacuflush system that only used a pint of FW per flush, I would do so in a second. I have had the intake thru hull pick up seaweed which, like any intake, can be a contortion to pick out. You only find out its blocked, with a bowl full ready to flush. Hate that.
Jeanneau 54DS
Minnewaska is offline
post #8 of 16 Old 08-14-2012
Senior Cruiser
sea_hunter's Avatar
We have a fw option that we use from time to time that keeps the sanitary lines clear and clean.
sea_hunter is offline
post #9 of 16 Old 08-14-2012
BTW, one of our departure checklist items is to fill the toilet bowl to the rim with freshwater from the sink and flush it. Only the intake lines are an issue.
Jeanneau 54DS
post #10 of 16 Old 08-14-2012
ex-Navy
bloodhunter's Avatar
One of my wife's requirements when we bought our boat was a new head that would eliminate the smell (I agree with Minnewaska, it's a very bad smell) After some research I ripped out the old head anmd put in a Vacuflush system and added an extra freshwater tank just in case. Turns out the system uses very little water and there is no more smell. Whether you go that route or not depends on on how sensitive your nose is. I put in the vacuflush orginally because I wanted my wife to sail with me but I have to admit that she was 100 pct right. Our boat is much more pleasant without the head odor that did tend to linger
Added note: We sail mostly in he Chesapeake where I suspect the water has more microorganisms than your average salt water and probably produced worse smells..
Sufficient unto the day is the evil thereof
S/V Enchantress -- Morgan 45
bloodhunter is offline
Fresh Water cooling water dirty brown sailak Gear & Maintenance 17 07-31-2009 11:52 PM
Smelly water from fresh water tank Bruce_Olson Gear & Maintenance 20 09-01-2007 04:42 PM
Fresh water boat to salt water svs3 Boat Review and Purchase Forum 6 12-30-2006 12:41 PM
convert from sea water to fresh water cooling.... john232 Gear & Maintenance 3 02-16-2004 03:44 PM
MD3B Volvo-Penta sea water to fresh water conversion slosharron Gear & Maintenance 20 06-17-2003 09:08 PM
