Old 08-14-2012
brucemoody is on a distinguished road
Clearing the Holding Tank Vent Hose
Recently purchased a Hans Christian 33. We're dealing with foul odor from the head and going after all variables in play. We bought the boat from a person who spent weekends aboard it but never took it out to sail. When we took ownership of the boat, her holding tank was completely full. The macerator wasn't wired for power. Consequently, flushing the toilet would force effluent through the vent hose and out those nozzles on the starboard bow. That's great for crowd control but not so much when trying to make a good impression at a new marina. The macerator is now wired and working like a champ, we've emptied the holding tank and flushed it with water and a bottle of treatment. Still, I am certain those vent hoses are jammed and not allowing air to pass. Any ideas of how to clear the vents? Thanks!
[SIGPIC]New at boat ownership.
and
about it. Join the conversation. Advice welcome!
  #2
Old 08-14-2012
Tempest is on a distinguished road
Re: Clearing the Holding Tank Vent Hose
How difficult would it be to just replace them? Mine is pretty accessible..I'm not familiar with how yours are run.
Tempest
Sabre 34
Morgan, NJ
  #3
Old 08-14-2012
DRFerron's Avatar
The most female moderator
DRFerron is on a distinguished road
Congrats on your new boat!
I don't know how your hose is configured, but ours exits the boat and runs into a stanchion. We disconnected the hose on the inside and forced water through it. Worked great.
Additionally, even if you clear the gunk out that created the clog, something will still stick to the sides. As long as the hose is dirty you might have an odor. That goes for any hose on your boat. You might want to think about removing and replacing them all.
Donna
Catalina 30
Rock Hall, MD
Contributing Editor
magazine
SSCA Rock Hall Cruising Station
  #4
Old 08-14-2012
sea_hunter's Avatar
Senior Cruiser
sea_hunter is on a distinguished road
Try putting the fw hose over the vent cover while you're pumping out. Sometimes when the boats been sitting it doing a crossing with full tanks it backs into the vent or a bug has made a home in the vent. Backflushing it will usually clear it if plugged.
  #5
Old 08-14-2012
CapnBones's Avatar
CapnBones is on a distinguished road
Replacing old hoses is always the best... That being said, when I pump out if I think my vent hose is clogged and sometimes just for good measure I put the freshwater hose up to the vent and blow water in while the vacuum from the pump helps pull and it clears out nicely. As sea hunter said.
  #6
Old 08-14-2012
Minnewaska will become famous soon enough
Our vent line exits the side of the boat. However, from the inside, you can see that it makes a loop up by the decks and then returns down to the fitting. I'm sure this is for anti-siphon. However, simply directing a hose spray from the outside, is not likely to make it to our tank. If I were to force the hose into the fitting, it would pressurize the tank, as the displaced air would have nowhere to go. The vent is blocked! Even opening the pumpout fitting may not work, as the intake is likely below the tank contents, so air will not escape. Be careful.
Jeanneau 54DS
  #7
Old 08-14-2012
sea_hunter's Avatar
Senior Cruiser
Replacing the hoses is a lot of work especially when not required; the tank vents from the top NOT the bottom, flushing some water through it may be all it needs. Stop looking for the hard when easy is mostly best.
  #8
Old 08-14-2012
CapnBones's Avatar
Like I said, while drawing a vacuum with the pump out, spray the water. This not only forces the water in (pressure of the hose) but it should be drawing air in through the vent (or trying to anyway). My vent is on the side of my hull as well and it fixed my clog like a champ.
  #9
Old 08-14-2012
MarkSF is on a distinguished road
Are you aware it's illegal to empty the holding tank in coastal or internal waters, macerator or not? Please use pumpout facilities.
Bristol 31.1
  #10
Old 08-14-2012
I wasn't disputing your advice. But you have made me think of whether the input from the hose would match the suction from the pump out. Probably not. In this case, I suspect a vacuum might be created in the tank.
Jeanneau 54DS
Tags
head , holding tank , odor , vent hose
You may post attachments
You may edit your posts
Clearing a vent and/or vent hose... svjobeth Pacific Seacraft 9 01-23-2012 08:00 AM
Holding Tank Vent tdw Gear & Maintenance 21 09-02-2010 09:32 PM
holding tank vent tugboatdon Gear & Maintenance 11 05-21-2010 11:39 AM
Holding tank thruhull vent Sixbrothers Gear & Maintenance 20 05-20-2008 03:27 AM
Holding tank vent.. groundhog Gear & Maintenance 9 06-18-2007 07:37 PM
SEO by vBSEO 3.6.1
