SSB weather on PC - Bahamas - SailNet Community
post #1 of 5 Old 08-14-2012 Thread Starter
I have a Kaito SSB receiver
Buy.com - Kaito Electronics Inc. KA1102SLV Digital AM/FM/SW World Receiver with SSB
and would like to use it to receive weather information in the Bahamas as I will be away from from the main cruising hubs most of the time. My understanding is that you tune in at a specific frequency at a specific time, plug in the sound output into the laptop microphone jack and have a software program decode and render the message. However, I was not able to find good documentation on how to do this on a laptop with free software. Does anyone have good advice here?
Also, where can I find the frequency and times for weather forecasts in the Bahamas?
Any other suggestions on getting weather information on the cheap down there? I really like ZyGRIP, but not sure how to get their weather data without an expensive satellite phone or Pactor modem.
Thanks!
Thomas
Tartan 34C
New York City
tominny is offline
post #2 of 5 Old 08-14-2012
Sailboat Reboot
svzephyr44's Avatar
Send a message via Skype™ to svzephyr44
Re: SSB weather on PC - Bahamas
The broadcast times and frequencies are at http://www.nws.noaa.gov/om/marine/rfax.pdf
The software you need is MultiPSK available at index MultiPSK is massive overkill - you will struggle with trying to figure out how to use it - hint you press the button HF FAX and then tune. Take the earphone output from the radio and feed it into the microphone input on the PC. That's all it takes.
Both the document and the software are free.
CAPT Roger J. Jones USN (ret.)
Sailboat Reboot
411 Walnut Street, #9700, Green Cove Springs, FL 32043-3443
Reboot's Agent's Email:
Web Site:
Blogging:
Twitter @Sailboat_Reboot
svzephyr44 is offline
post #3 of 5 Old 08-14-2012
Call me Ishmael
blowinstink's Avatar
Hi
There is a lot of good info here:
Marine Radiofax charts
In particular look at the radiofax users guide. I had very limited success in downloading weather faxes (I could get some content but never worked out the kinks well enough to make consistent use of it). You'll need to download the freeware and also to buy a cable (cheap) which connects your radio to your laptop.
Also, check out your explorer charts (or whatever cruising guide you are using) to find out the current frequencies for Chris Parker's voice broadcast each day (Mon - Sat). You can also see his webpage here:
Marine Weather Center - Bahamas & Caribbean Marine Weather Services
When you have internet access you can watch the web simulcast at this site:
GreenLight Web
Hopefully someone who has had better luck with the weatherfax reception can help us both out -).
Luck,
Matt
blowinstink is offline
post #4 of 5 Old 08-14-2012
Warm Weather Sailor
Vasco's Avatar
All you have to do is tune into Chris Parker in the morning. He gives the best weather for the area. Marine Weather Center - Meet Chris Parker
A little Sony and it'll usually boom in.
Sony ICF-SW7600GR AM/FM Shortwave World Band Receiver with Single Side Band Reception, plus External Plug-in Antenna
Rick I
Toronto in summer, Bahamas in winter.
Vasco is offline
post #5 of 5 Old 08-14-2012
RichH's Avatar
Ditto with Caribbean Weather by Chris Parker .... for the best and most comprehensive weather forecasts for the Bahamas and more importantly for crossing the Gulf Stream.
Schedules and frequencies are found on Marine Weather Center - Marine Weather Center Services
When using a HF shortwave receiver, consider to use an external antenna 'long wire' (just an insulated simple wire that is pulled high in the rigging) or a simple 'dipole' made of the same wire ... will be MUCH more effective than the usual 'internal' antenna on most portable shortwave radios.
If you dont already have a portable shortwave radio ... one of the very best for the price is: http://www.amazon.com/Sangean-ATS-909X-World-Band-Receiver/dp/B003XU76PQ/ref=sr_1_2?ie=UTF8&qid=1345003023&sr=8-2&keywords=sangean+shortwave+radio
In the popular cruising destinations such as Marsh Harbour or Georgetown, etc. you can tune in in the morning on VHF for weather forecasts through the local cruisers nets.
RichH is offline
Bahamas maybe? jkiser General Discussion (sailing related) 17 12-21-2011 10:45 AM
322 O''Day to Bahamas Booher Cruising & Liveaboard Forum 9 01-10-2010 07:23 PM
Bahamas Weather Forecast Snboard976 Gear & Maintenance 3 01-09-2010 10:14 AM
Navigation / Communication / Weather for Bahamas Cruise Pelham Cruising & Liveaboard Forum 9 12-30-2006 06:30 PM
Bahamas. Great Exuma Island, Bahamas set to host Exuma Celebrity Bonefish Classic @ BYM Sailing News NewsReader News Feeds 0 04-14-2006 04:15 AM
