Changing an Alternator Pulley - SailNet Community
post #1 of 4 Old 08-16-2012 Thread Starter
Hi, I purchased a Balmar 6 series alternator for the Westerbeke 55A engine. Unfortunately the pulley is too far back by less than a 1/2 inch and the belt is hitting the nut on the tension rod. Balmar suggested a new pulley which will give me just the right angle. Does anyone have experience with romoving the pulley and replacing it? I would like a some advice...is it necessary to have this done with pneumatic impact wrench or has anyone done this by hand?
Thank you,
Sailor Chris
sailorchris is offline
post #2 of 4 Old 08-16-2012
Maine Sail's Avatar
Re: Changing an Alternator Pulley
You will need an impact driver.. Any auto shop should be able to zip it off and put the new one on in about 3-4 minutes..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #3 of 4 Old 08-16-2012 Thread Starter
thank you...appreciate the response. I will try PepBoys around the corner this weekend.
post #4 of 4 Old 08-17-2012
Aspiring to be a Mexican
sww914's Avatar
I concur, an impact turns a PITA job into nothing here.
sww914 is offline
Balmar Pulley Size montenido Electrical Systems 2 05-15-2012 04:35 PM
Pulley wheel ambianceack Gear & Maintenance 8 03-22-2010 05:18 PM
Yanmar PTO v-pulley gramcko Gear & Maintenance 3 01-16-2008 01:18 PM
It's a Sheave, not a Pulley sailaway21 Gear & Maintenance 35 12-13-2007 12:52 PM
pulley for centerboard capterry Irwin 1 11-13-2006 01:43 PM
