Old 12-26-2012
Barquito's Avatar
Barquito
Barquito is on a distinguished road
Re: Catalina 27 Maintenance - Where to start
Do maintenance and upgrades on stuff that could become a safety issue first. Motor, thru hulls, any plumbing below water line, standing rigging, jacklines... then make sure the head works, then go sailing. You can try to be pro-active about maintenance, but, you will still be continually fixing stuff that breaks.
chef2sail likes this.
Bristol 27
Cirque
  #12
Old 12-26-2012
Hudsonian is on a distinguished road
Bulkhead and chainplates are critical. A good article by Dan Witucki on the website epoxyworks.com. has detailed information on replacing rotted bulkheads. The leaks that lead to bulkhead rot will keep the bolts and chain plates moist, thereby, promoting crevice corrosion.When you remove the chainplates, check the SS bolts for crevice corrosion.
On most boat projects, the value of the labor far exceeds the cost of materials. Do the work right, using the right materials to avoid having to do it again.
  #13
Old 12-26-2012
bratzcpa's Avatar
bratzcpa is on a distinguished road
We bought a 1973 C27 last year - - and have LOVED it. An awesome boat for us. We did lots of small cosmetic things right away because it was SO ugly (painted gray non-skid, refinished wood), and replaced a couple of sails. I'm pretty particular about the electrical stuff (I really really insist that when you switch something "on", it should actually go on . . . so replaced all of the wiring and put in a new electrical panel.
This winter we are replacing all of the standing rigging. They're currently done with corroding Nicopress. No problems, but they looked scary.
We added an organizer and clutches when we ran the halyard lines to the cockpit.
New Tiller handle (old one was rotted and broke off in our hands). We were at the dock, or that would have been WAY exciting.
There are a bunch of thru-hulls with gate valves (rusted/frozen solid) that are getting replaced in spring too. They were bad bad bad, but we lucked out on that too.
We also added some "handy" improvements just cause they were fun and we wanted too: permanent boarding ladder on the stern, changed the name and added 'cool' lettering/logo on hull, headsail bag so we can leave the jib hanked on, GPS with charting software, solar panels that we can plug in when we're off the boat (not permanently mounted - - - yet).
My suggestion - deal with safety issues first, and do a few fun things to make it "yours" too.
You did good - - -an awesome boat for sure.
~markb
chef2sail and Barquito like this.
~markb
S/V "New Girl" on the dock
Catalina 27
  #14
Old 12-26-2012
Mark1948 is on a distinguished road
If you are still on the water and want to putter, I would spend time rebedding hardware and focus on anything that appears to be leaking. Oil you teak just to keep it fresh and good looking. Oil and fuel filters etc are annual. When you do change oil, flush the engine with new oil, a couple of quarts to make sure you got out the old dirty stuff. Don't forget to clean the fresh water strainer. Do check the alternator belt and all hoses for cracks. If you find that the head tends to get back flow into it you may need to replace the back flow valve.
You may post attachments
You may edit your posts
Catalina 34MK vs Catalina 36MK Neicy Boat Buyers & Sellers Forum 8 02-13-2012 04:26 PM
1994 Catalina 320 vs 1992 Catalina 36 ChuckBuck Boat Review and Purchase Forum 8 01-10-2012 09:42 AM
Perkins 18HP Catalina 270 Engine Won't Start Trescool Gear & Maintenance 21 11-20-2010 10:14 PM
Catalina 30 Keel cracks (not Catalina Smile) Pelham Catalina 5 12-01-2009 10:39 AM
Catalina 27 70's era Maintenance Question saurav16 Catalina 6 01-09-2008 10:43 PM
SEO by vBSEO 3.6.1
