Catalina 27 Maintenance - Where to start - SailNet Community
 6Likes
post #1 of 14 Old 08-18-2012 Thread Starter
I recently purchased a 1985 Catalina 27 Tall Rig with an inboard diesel. I really want to be proactive about maintenance, but I am a bit overwhelmed as to where to start. The boat is generally in good shape and given all of the books I've read about surveying, engines, and maintenance (including Good Old Boat, Calder's texts, etc.) there doesn't seem to be anything glaring that requires immediate attention (big knock on wood here). I'm also an little wary of introducing variables as things are working and I would like to enjoy the boat the rest of the season. I also believe the previous owner was fairly active with maintenance and hit most of the major pre-season items. Any thoughts as to where to start applying time/money?
engineer_sailor is offline
post #2 of 14 Old 08-18-2012
Senior Smart Aleck
jameswilson29's Avatar
Re: Catalina 27 Maintenance - Where to start
Where to start? Owner's/operator's manual for diesel inboard - should include a maintenance schedule.
If you want to become acquainted with your inboard and routine maintenance, you can start by checking/replacing the impeller and cleaning the raw water strainer (if it has one), changing the oil and oil filter, changing the transmission fluid, changing the primary and secondary fuel filters, changing the coolant and checking the heat exchanger, checking the alternator belt, and checking/replacing all hoses around the engine.
You should probably also check all seacocks and hoses and check the rigging. Also, check the battery bank and condition of the batteries.
Tempest and chef2sail like this.
jameswilson29 is offline
post #3 of 14 Old 08-18-2012
swimnfit's Avatar
Congratulations! The C27 is a great little boat.
Most of the Catalina family has some great owner support groups where you can get answers to most if not all of your questions specific to your boat.
Start Here : International Catalina 27/270 Association
A wet sheet and a flowing sea, / A wind that follows fast / And fills the white and rustling sail / And bends the gallant mast.
swimnfit is offline
post #4 of 14 Old 08-18-2012
Greenflash35's Avatar
Rumor has it only takes three days in still water to start a barnacle farm.
GreenFlash35
Greenflash35 is offline
post #5 of 14 Old 08-18-2012
Just go sail the hell out of it.
I have a C27. You'll love it.
smackdaddy is offline
post #6 of 14 Old 08-19-2012
SchockT's Avatar
You definitely need to take care of that engine because if it packs it in, you will spend more to repower than the boat is worth, or you will be installing an outboard! Definitely make sure it is up to scratch, and keep it that way. If you are not familiar with marine diesels, consider paying a mechanic to come down and check it out, and pay attention while he does it!
You obviously want to watch out for signs of corrosion on the standing rigging, and make sure all of your turn buckles and clevis pins have cotter pins or rings in them so they can't back off or fall out. After that just start using the boat. Deficiencies will start to appear as you get to know the boat and your knowledge increases.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #7 of 14 Old 08-19-2012
gts1544
A journey of a thousand miles begins with one step! Prioritize and then tackle one area at a time and see it through to fruition. Use a digital camera and keep a log, preferably on your computer, backed up! The log will prove to be invaluable. gts1544 - retired airline pilot afflicted with the dreaded disease known as airline anal. But it kept me alive in the sky for 50 years!
gts1544 is offline
post #8 of 14 Old 08-19-2012
Don't forget the little zinc in the hear exchanger. I just checked mine, and it was gone.
RobGallagher likes this.
MarkSF is offline
post #9 of 14 Old 12-25-2012
Anything-Sailing Founder
ckgreenman's Avatar
Send a message via AIM to ckgreenman Send a message via MSN to ckgreenman Send a message via Yahoo to ckgreenman
Congrats on your new boat. I recently bought a 1984 C27 std rig and have my hands full trying to go through all the systems myself. I just found and fixed an oil leak on the M18 ($4.19 for a new oil filter) and have been going through all the portlights trying to solve the water leaks. The only MAJOR projects I have is replacing the rotted bulkheads. I'll be buying a sheet of plywood for that soon. lol
Good luck and enjoy!!!
cM(not k)greenman
Chris
S/V "The Jade Dragon"
1975 O'Day 25
Meet me at
Ignore Power = Currently Rebuilding
ckgreenman is offline
post #10 of 14 Old 12-26-2012
blutoyz's Avatar
We are in basically the same situation so I will share what I have decided to do (with good advice from the Admiral I must admit).
The old "if it aint broke" applies so do the maintenance recommended and inspect all rigging and then as smack wrote "sail the crap out of it". We will both soon find out what we want to change/upgrade on our boats as we see fit.
Bill
blutoyz is offline
1994 Catalina 320 vs 1992 Catalina 36 ChuckBuck Boat Review and Purchase Forum 8 01-10-2012 09:42 AM
Perkins 18HP Catalina 270 Engine Won't Start Trescool Gear & Maintenance 21 11-20-2010 10:14 PM
Catalina 30 Keel cracks (not Catalina Smile) Pelham Catalina 5 12-01-2009 10:39 AM
Catalina 27 70's era Maintenance Question saurav16 Catalina 6 01-09-2008 10:43 PM
