  #21 (permalink)
Old 03-03-2010
NorthPointCatalina38 is on a distinguished road
Kiwi or other feathering propeller
Since it has been a year since the last posting, I'm curious to know if anyone has updated experience with any of their feathering props - positive or negative?
How do the Kiwi props hold up over time?
Are there comments from owners of other brands?
Are you satisfied with their ability to maneuver in tight marinas - is it significantly better than your fixed blade props if that is what you changed out?
Thanks much!!
Scott
  #22 (permalink)
Old 03-06-2010
sailIC is on a distinguished road
I'm actually the original poster and stumbled over this post on another search. I did move ahead an bought a Kiwi prop, and even if I sold the boat four years ago i did use the boat on an 2 month cruise with it.
Overall i was pleased with the prop. As expected, the sailing performance improved especially in light air. By engine, it lost some bite forward most noticable in heavier seas. Good reverse and the prop walk which was significant on the fix prop dissappeared. I got a line in the prop which pulled the engine out of alignment but with no dammage to the prop.
I would buy it again, price and good enough being the two main reasons.
  #23 (permalink)
Old 03-07-2010
brokesailor's Avatar
SV Skalliwag #141
brokesailor is on a distinguished road
On a Hunter 36 I replaced the stock fixed three blade with a 3 blade kiwi. Best thing I ever bought for the boat. Prop walk is completely gone. Under power going into the wind up the Potomac at 20-25 KTS I was doing about 6 KTS. With the old prop I would have been lucky if I did 3 KTS undr those conditions. Sailing performance has also improved picking up .5-1 KT.
  #24 (permalink)
Old 03-07-2010
sailjunkie's Avatar
Mirage 29
sailjunkie is on a distinguished road
One of the previous owners had installed an L/H pitch Kiwi Feathering Prop on our 29 foot boat. As others have said, no problems.
One further note, there is minimal prop walk in reverse and none in forward. It is early days for us, but so far, so good.
  #25 (permalink)
Old 03-07-2010
night0wl's Avatar
night0wl is on a distinguished road
Just ordered the Kiwi Prop for our Beneteau 343. We have pretty bad prop-walk, so I'm hoping to get cured on that. Also, in 10-12 knots of wind, I usually make a little over 4 knots SOG with my fixed 3 blad prop. People have called my fixed prop the equivalent of a bucket being towed behind us
Will report on our experience when I get Jendai back in 2 weeks after our haul-out.
S/V Jendai
Beneteau 343
  #26 (permalink)
Old 03-08-2010
Before everybody think the Kiwiprop is the best thing since sliced bread, below is the thought process I went through before buying one. Here is to me a simple summary of the different pros/cons by prop type
Fixed
Pros: Best engine performance, reliable, cheap
Cons: Huge drag when sailing
Folding:
Pros: Lowest drag when sailing, Medium price
Cons: Poor engine performance especially reverse, reliability
Feathering:
Pros: Almost as low drag as folding, almost as good by engine as fixed
Cons: Very expensive
The really good thing with the Kiwiprop is the price. I think that’s the main reason why you buy it. I do think other much more expensive feathering props has slightly lower drag but the Kiwiprop is huge improvement over fixed.
When I got it I was also very impressed by the simplicity of the design. Aside from braking the replacable blades, I cannot see what can break.
I cannot understand why the propwalk almost disappeared. It might have something to do with that when the blade flips it will have the same leading edge both forward and reverse. Also (if I remember correctly), the reverse pitch (not adjustable) was very high. Might have something to do with it, but it did work.
The only negative that surprised me was that the propeller rotated whilst sailing. Cannot understand why it did with freely feathering blades, but it has to generate some resistance. Easily fixed by putting the gearbox in reverse, but I heard of problems if you have a hydraulic gearbox.
All in all, I would definitely buy it again.
  #27 (permalink)
Old 03-08-2010
SV Skalliwag #141
I must apologize to the group. I have a Gori prop not a Kiwi.
  #28 (permalink)
Old 03-13-2010
Shortman is on a distinguished road
Headed into my fourth season w/mine on a Pearson 34 with a Yanmar 3GMF. Quite happy with it. Greatly reduced walk. Much better reverse. Chipped one blade corner on a log first season, have not replaced because damage small, BUT it is replaceable. A little grease every spring. Deal direct w/mfg. & they're very responsive.
Zincs for Sail Prop feathering prop jrbarn Gear & Maintenance 4 09-20-2006 10:40 AM
Max prop on a saildrive levenezia Gear & Maintenance 16 09-20-2006 12:07 AM
Propeller performance change - feathering paulmcquillan Gear & Maintenance 2 10-20-2003 07:48 PM
Prowell feathering Prop Zincs Alohakate Gear & Maintenance 0 06-13-2002 04:12 AM
Feathering and folding props FredSprigman Gear & Maintenance 3 09-08-2001 06:21 PM
