Like Tree3Likes
  #1
Old 08-19-2012
verestsailnet is on a distinguished road
propeller not turning
I have an Islander 32 with a volvo penta MD7A inboard. The engine turns on. Transmision spins the shaft turns forward and in reverse as expected; however, the prop does not turn. My thinking is that the propeller became loose. I see the propeller is there but it simply does not turn and the shat is turning. Help needed before diving in to determine how to fix it. Recently I had the shaft fitted with a new zink. Is it posible that they removed the propeller and did not install it correctly? It worked fine for about two hours. How is this posible?
Thanks
  #2
Old 08-19-2012
ParadiseParrot is on a distinguished road
Re: propeller not turning
Missing key maybe?
rugosa likes this.
  #3
Old 08-19-2012
Thanks, a minute ago I spoke with to a diver that provides propeller replacement and he stated that it is likely that the key broke.
  #4
Old 08-20-2012
SimonV's Avatar
Wish I never found SN!
SimonV will become famous soon enough
Either the keys sheared, or the prop fell off.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location Back in Brisbane
DELIVERY SKIPPER
  #5
Old 08-20-2012
DivingOtter's Avatar
Otter
DivingOtter is on a distinguished road
Sounds like a bad keyway
  #6
Old 08-20-2012
Otter
They wouldnt have removed the wheel ( well they SHOULDNT have ). The zincs around the shaft should piece around it. Just make sure you use a reputable INSURED diver. There are way too many fly by nights out there.
  #7
Old 08-20-2012
Great advice. It is good to know that the propeller was not removed when replacing the zinks. I'll will check on insurance and reputation, before hiring the diver.
The key must be broken. I must have been bad for a while and it finally broke. If anyone knows what could have couse the propeller key to shear that would be great knowledge to everyone.
thanks
  #8
Old 08-20-2012
SchockT's Avatar
SchockT is on a distinguished road
I doubt very much the key broke, because if it did, where would it go? It is trapped half in the prop keyway and half in the shaft keyway, and there is zero clearance between the shaft and the prop hub. It is possible that the key fell out, but if it is anything like my shaft that is next to impossible to. The most likely scenario is that somebody installed the prop without the key, and instead was relying on nut tension and the shaft taper to keep the prop tight. Regardless, if the prop has been spinning on the shaft, you are likely going to have to deal with a damaged prop and shaft. I would be surprised if a diver could do anything more than tighten it up enough to get you to the nearest haul out. If you have a haul out nearby you should get a tow to the lift, and put the diver fees towards the haul out where you can properly inspect and repair the problem.
rugosa likes this.
1979 Santana 30 Tall Rig
Hull#101
  #9
Old 08-20-2012
Otter
Many things could cause it to give. Poor fit, corrosion due to old age, fatigue or even play in the cutlass bearing causing "chatter" in the shaft resulting in harmonic imbalance or sympathetic resonance over time causing the break.
  #10
Old 08-20-2012
Otter
Relying on nut tension alone wont work. As soon as torque is put onto that shaft it would free spin. Ive seen keyways that were too big resulting in not being able to remove the wheel, and keyways that were too small resulting in a shockload everytime gear was engaged.
You may post attachments
You may edit your posts
Keep Turning Left tinkturtle General Discussion (sailing related) 6 10-06-2009 08:59 PM
Turning Diesel Key Off? CapnSantiago Gear & Maintenance 16 09-05-2007 03:08 PM
Turning Passengers into Crew Bruce Caldwell Learning to Sail Articles 0 09-21-2004 08:00 PM
Turning Passengers into Crew Bruce Caldwell Seamanship Articles 0 09-21-2004 08:00 PM
Turning Passengers into Crew Bruce Caldwell Her Sailnet Articles 0 09-21-2004 08:00 PM
SEO by vBSEO 3.6.1
