Diesel engine compartment ventilation - Page 2 - SailNet Community
 1Likes
post #11 of 19 Old 08-21-2012
No more curry buffets
Ritchard's Avatar
Re: Diesel engine compartment ventilation
I like the idea of running the blower when under power to both remove any diesel stink, and also to keep things cooler on a hot day. However, my blower is LOUD! I wonder if I can somehow soft-mount the thing to quell the vibrations.
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
post #12 of 19 Old 08-21-2012
Barquito
Barquito's Avatar
I wonder how much air actually moves on a static set-up with two clam shells. Mine both have screens too.
Valiant 32
Barquito is offline
post #13 of 19 Old 08-21-2012 Thread Starter
Probably about the same amount that the diesel engine is pumping out of the exhaust
fryewe likes this.
MarkSF is offline
post #14 of 19 Old 08-22-2012
Gunga Din
Or the same amount the engine is taking in? If they're connected and the compartment is sealed.
Anyway, the hoses help to direct the flow to desired areas - like the alternator.
Gunga Din is offline
post #15 of 19 Old 08-22-2012 Thread Starter
The amount of air the engine is taking in, and the amount going out of the exhaust, are essentially the same.
MarkSF is offline
post #16 of 19 Old 08-22-2012
Gunga Din
Hi, MarkSF
I didn't mean to correct you or be rude but you're wrong. Not literally if you wanted to differentiate exhaust gases from air but, then, there's no air in the exhaust.
What I meant it's because the whole idea of an diesel/internal combustion engine it's the expansion thru burning/explosion.
Again, don't get me wrong. Just a comment.
post #17 of 19 Old 08-22-2012
MarkSF, I have the same thing, one facing forward ducked along the top for about a foot supplying fresh air into the eng compartment, the other faces to the rear and it's hose goes to the bottom, and pulles air out of the compartment.
AirborneSF is offline
post #18 of 19 Old 08-22-2012 Thread Starter
"there's no air in the exhaust"
Air is 80% Nitrogen and 20% oxygen. Exhaust is 80% Nitrogen and most of the rest is C02. It entirely depends on semantics, but you could say that exhaust is at least 80% air.
MarkSF is offline
post #19 of 19 Old 08-22-2012 Thread Starter
Thanks... I think that's exactly the info I needed to correct my plumbing.. the boat's that is...
MarkSF is offline
Best way to soundproof engine compartment? FrankLanger Gear & Maintenance 27 11-14-2013 10:30 AM
Engine compartment forced ventilation? Petar Diesel 3 10-27-2011 10:52 PM
Smell of Diesel fumes in Engine Compartment casey1999 Diesel 10 08-18-2011 11:17 PM
Engine compartment ventilation? Petar Gear & Maintenance 6 03-29-2010 12:51 PM
Engine ventilation PBzeer Gear & Maintenance 7 03-04-2007 11:52 PM
