Hole in hull - Page 2 - SailNet Community
 1Likes
post #11 of 15 Old 08-21-2012 Thread Starter
So much for 5 mins haha I would have to assume this would be more permanent the just pulling the floor board and filling the hole with epoxy
jfl14609 is offline
post #12 of 15 Old 08-21-2012
Re: Hole in hull
I'm glad this has come up as I have some holes from old seacocks to fill. The old ones had 4 holes and the new ones have 3. My holes are already bevelled from the bolt heads so i think i will use the 105 epoxy mixed with 406 silica to thicken it and some small pieces of fibreglass thrown in for strength. I have to fill my holes from the outside.
Trinidoc is offline
post #13 of 15 Old 08-22-2012 Thread Starter
Re: Hole in hull
i think the holes you have are a bit larger than mine is I say 1/4 in but realistically its prob 1/8 i would say a bb would barely fit in it. my original plan before asking people that knew what they were doing was to mix some resin and hardener up then roll up a tiny amount of fiberglass to fit in the hole. then soak it in the resin and stuff it in the hole. seems like others may have better ideas though
jfl14609 is offline
post #14 of 15 Old 08-22-2012
Re: Hole in hull
How did you get your hole? Was it a drill hole that was filled?
Trinidoc is offline
post #15 of 15 Old 08-22-2012 Thread Starter
Re: Hole in hull
it was a small drill they used to allow the boat to drain if any water got in over the winter trust me if that much water got in there (the hole was not well placed) i think you have bigger issues. the hole has never been filled
jfl14609 is offline
Suspect hole in hull KevinCo Boat Review and Purchase Forum 6 08-20-2012 04:13 PM
Re-using thur-hull hole? Tanley Gear & Maintenance 2 04-23-2011 07:00 PM
Drilling Hole in Fiberglass Hull sailak Gear & Maintenance 16 03-17-2011 10:37 AM
Drilled Hole in Hull Repair weephee General Discussion (sailing related) 22 08-04-2009 11:56 PM
Thru Hull Hole Sizing cas8100 Gear & Maintenance 1 07-10-2009 06:55 PM
