Black spots on the wood - Page 2 - SailNet Community
 5Likes
post #11 of 13 Old 08-23-2012
RichH's Avatar
Re: Black spots on the wood
Youre going to have to define better the black spots a bit better, their location in proximity to scarfs, bungs, joints, etc. ... and if the dark was UNDER any surface coating before you removed the varnish, etc. If so this a moisture condition that may be coming from BEHIND the wood and if the source of the moisture is not remedied no amount of bleaching, sanding or other prep work then recoat will be effective to last long ... until you remedy the moisture from getting behind, then migrating 'through' the wood or coming from behind the BAD joint. If the leak is from behind ... I sometimes apply/inject liquid clear 'athletes foot remedy' (look for the TIN content on the label) to kill off any mold that is 'inside' the wood (look up: "wood + spalling" ... or ... "wood + spalting") so you know what to look for. Spalting is wood that has been deeply penetrated and discolored via fungi.
If the black was created from a 'surface' leak of the prior coating being faulty ... TSP, oxalic, etc.
If this is 'really' surface mold/fungi, then TSP and/or sanding, followed by oxalic acid or clorox, etc. Teeny black specs. (lot of them) are usually caused by artillery fungus ... a fungus that lives on tree bark in cool humid climates - TSP followed by bleach.
Could also be a 'sap pocket' that was undiscovered in the original installation ... good luck with that.
RichH is online now
post #12 of 13 Old 08-24-2012
Using black shoe polish, add a thousand more 'spots' and say that animal prints are the big trend this year.
Personally, I like bare teak, oiled as needed. I'd rather install plastic than start getting into the wood maintenance cycle. Much as I love the look of crystal varnish and gleaming brass, I can't afford to hire the guy to manage the guy who'll find a guy to interview another guy to do all that maintenance on a daily basis. Reliably.
hellosailor is offline
post #13 of 13 Old 08-24-2012
rugosa's Avatar
If you're hiring full time, on a big boat, wife and I are in.
rugosa is offline
Replacing wood "curtain" with wood door in head area? Catalina 27 7tiger7 Gear & Maintenance 28 05-15-2014 09:21 PM
black piano wood? NewportNewbie Gear & Maintenance 17 08-25-2011 04:55 PM
Black smoke and black water bruceyp Gear & Maintenance 25 08-04-2008 12:00 PM
Best wood-to-wood adhesive kwaltersmi Gear & Maintenance 16 10-27-2007 07:25 PM
At sea. Volvo Ocean Race: Brasil 1 spots spinnaker problems on Black Pearl @ BYM Sailing News NewsReader News Feeds 0 04-12-2006 02:15 PM
