08-22-2012
Señor Member
Re: Black spots on the wood
Ross,
The discoloration is perfectly normal, and is NOT indicative of rot. What I'd recommend is to begin with the least destructive method first then progress to bigger guns as required.
That said, you probably won't need to go beyond a gentle cleaning with water, a white scrub pad and some Bar Keeper's Friend.
The key ingredient in BKF is oxalic acid, which will bleach out the discolored areas. It also has no abrasive material that will do damage to your teak. Likewise, use the white scrub pad (never a green one) to keep from removing the softer wood between the growth rings.
You could also try a commercial teak cleaner, but I'd try BKF first since it's cheap and a can will last a long time.
