02-19-2004
Handheld GPS recommendations
I have been the owner of 3 Garmin Units: the 48, the 12, and, currently, the GPS76 MAP. I would HIGHLY recommend buying a Garmin and, if you need supreme accuracy, a Garmin with WAAS capabilities. All of my units have been somewhat waterproof, float, and are very easy to use. You might want to check practical sailor''s site; Im sure they have a review of handheld GPS''s. Not sure if you have a tiller or a wheel but you can get a RAM mount and mount the GPS right at the steering station. If you put it inside the boat you will, most likely, need an external antenna. I would suggest that you goto a West Marine or similar store and see any GPS your are considering buying in action; I have found that the smallest ones have screens that are near impossible for me to read.
