AutoHelm 5000 problems - SailNet Community
post #1 of 5 Old 08-26-2012 Thread Starter
Hello Everyone,
I have been having issues with my AutoHelm 5000 autopilot. I am hoping that I can re-calibrate my control unit's compass and fix these issues. But, I can not find instructions for doing this. I have the original manual and it has no directions for calibrating the compass. I know that some models you push a series of buttons and then put the boat in two slow 360 degree turns. I just don't know the proper sequence.
It is an older model so there is not much tech support. I am hoping someone here might have an answer.
Thank you,
Matthew
MatthewM is offline
post #2 of 5 Old 08-30-2012
Re: AutoHelm 5000 problems
If you have the old 5000, not the "ST" version, I do not think that compass calibration is available.
CaptainDan99 is offline
post #3 of 5 Old 08-30-2012 Thread Starter
Thanks Captain,
I was starting to suspect this was the case. The autopilot operates erratically, sometimes working fine and then falling off course. Other times not following a course at all. With a unit this dated maybe it is time to replace it.
MatthewM is offline
post #4 of 5 Old 08-30-2012
THEFRENCHA's Avatar
I think I have the 5000 and to calibrate :
From memory as I am not on the boat
Press Standby for 2 seconds
Screen will change and ask you questions
Press the orange light button and go to Swing and start counterclockwise circles at low speed
Should work!
THEFRENCHA is offline
post #5 of 5 Old 05-09-2015
PM that I could not send. Would greatly apprecaite if somsone could forward this to his attention or if anyone else has this information
Captain Dan. Was googling autohelm 5000 attempting to find wiring information to hook this up through some relays with a generic linear drive.
I noticed that you mentioned to another user that you had the wiring pinouts and/or color codes available at that time. Do you still happen to have these?
Technarchy is offline
Autohelm ST4000 Plus problems Outrageous Electronics 47 01-23-2015 08:20 AM
autohelm 5000 ralphmacey Electrical Systems 1 07-18-2012 09:03 PM
Nautech Autohelm 5000 brokesailor Electrical Systems 3 06-09-2011 08:49 AM
Autohelm AH800 problems corny Gear & Maintenance 0 08-18-2009 10:05 AM
Raymarine Autohelm ST1000 Problems And Raymarine Warranty petertribo Gear & Maintenance 9 07-27-2008 10:36 PM
