Old 08-27-2012
Grand River Raider is on a distinguished road
Transmission Diagnostic Advice
My boat is a 1981 C&C 32 that I have had for 3 months. It has the original Yanmar 2GM engine. Not sure of the model of the tranmission. The motor mounts were replaced within the last 2 years as was the cutlass bearing. The bearing was tight prior to be splashed in the spring.
The boat was making a loud clunking noise in forward gear when throttling up from idle speed still at low rpm (not sure of exact rpm). I would be able to go back down to idle and then throttle up again to full rpm without further incident. This problem has happened off and on all season, but has not happened consistently. Not sure of the rhyme or reason for the inconsistency. It did not happen in reverse.
Yesterday, after motoring out of the harbor without any problem, sailing for a while, then motoring again (probably for a total of about 1 hour for the day), the problem occurred again, only this time the boat would no longer go into foward gear at all. Looking down through the lazarette, I could see that the lever was still activating when shifting from the pedestal, but the prop shaft would not turn forward any longer. The prop shaft would make a brief jolt like it was trying to turn forward, but would not spin. It would still turn in reverse and the boat still runs in reverse normally.
Any suggestions on the potential problem?
  #2
Old 08-27-2012
jsaronson's Avatar
jsaronson is on a distinguished road
Re: Transmission Diagnostic Advice
Hate to be the bearer of bad news, but you are in for a rebuild. Sounds like the clutch.
You may post attachments
You may edit your posts
Who has a ZF BW7 transmission? prroots Beneteau 6 10-18-2011 04:26 PM
Hurth transmission advice needed evenstephen Gear & Maintenance 2 06-15-2011 01:35 AM
NYC Espar HELP! Need Diagnostic Unit! SVArgo US Northeast 0 02-10-2011 01:32 PM
NYC Espar HELP! Need Diagnostic Unit! SVArgo Pacific Seacraft 0 02-10-2011 01:30 PM
Where can I get a ZF 15 MIV transmission? leclare Diesel Engine Forum 0 07-26-2010 02:14 AM
SEO by vBSEO 3.6.1
