IB30 cutlass bearing removal - SailNet Community
 1Likes
  • 1 Post By Ritchard
post #1 of 6 Old 08-27-2012 Thread Starter
Islander Yacht Fan
ECS-IB30's Avatar
has anyone removed the strut (cutlass) bearing on one of these boats....looking for best diy method....is it a sleeved bearing?
ECS-IB30 is offline
post #2 of 6 Old 08-27-2012
Tartan 27' owner
CalebD's Avatar
Re: IB30 cutlass bearing removal
ISLANDER BAHAMA 30 sailboat specifications and details on sailboatdata.com
Most cutless bearings are sleeved, especially in a strut.
DIY?
- remove shaft
- if press out method using threaded rod, washers, small section of pipe matching ID of bearing does not work (and it usually doesn't), then
- hack saw blade to score the sleeve of the bearing. Once a clean cut is made you peel it in on itself.
Here is a very good step by step guide: Replacing A Cutlass Bearing Photo Gallery by Compass Marine at pbase.com
Everybody has one:
CalebD is offline
post #3 of 6 Old 08-28-2012
I replaced mine last year on a 1981 B30, it is sleeved, cut it in two or three spots and it should come out real easy. Be careful the sleeve is very thin after you get through the rubber bearing. I used a threaded rod about 1/2 inch and washers to press the new bearing in. Good luck!
kentg is offline
post #4 of 6 Old 08-28-2012
oh yea and post to the Islander thread not general, there is some good knowledge to be had!
kentg is offline
post #5 of 6 Old 08-28-2012
No more curry buffets
Ritchard's Avatar
Not sure if this will work for you, but here's what I did, I made up a custom but cheap tool. This is mostly because I didn't want to fuss with removing the shaft - the space behind my engine is SMALL.
Low buck projects- Let's see 'em!
CalebD likes this.
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
post #6 of 6 Old 08-28-2012 Thread Starter
Islander Yacht Fan
ECS-IB30's Avatar
success!
Thanks to all for the speedy replies...cut two slots w hack and sawzall and it came right out!
It is listed in buck algonquin as pn albacore...
ECS-IB30 is offline
Cutlass Bearing and rudder bearing smillinjack Gear & Maintenance 3 07-11-2010 08:18 PM
Cutlass Bearing Removal Tool DrB Gear & Maintenance 7 04-12-2010 03:48 PM
Cutlass Bearing Help kccollbran Gear & Maintenance 5 03-25-2008 12:57 PM
Where do you buy a Cutlass Bearing ? clayjay Gear & Maintenance 2 08-02-2007 09:29 AM
Cutlass bearing lgsailor52 Gear & Maintenance 5 07-04-2002 06:25 AM
