LED: AC to DC - SailNet Community
post #1 of 5 Old 09-02-2012 Thread Starter
LED: AC to DC
Costco has a package of 4 strip LEDs for $30. They can be linked as one long LED or connected with varying lengths of wire. They come with one hi / lo switch and the plug / transformer that steps the AC down to LED levels.
Can one simply cut off the plug / transformer and connect the two wires to a 12V battery?
Thanks
i_amcdn is offline
post #2 of 5 Old 09-02-2012
Seņor Member
PorFin's Avatar
Re: LED: AC to DC
That depends...
Take a look at your brick (transformer). What's the output voltage?
PorFin is offline
post #3 of 5 Old 09-02-2012
asdf38's Avatar
LED: AC to DC
Edit: I didn't read this too carefully.
As suggested you're probably ok if the brick is 12v, if no you may have a problem either being too dim or too hot. However the odds that it's 12v exactly aren't that high (said by someone whose never used these before). Also, although the LEDs themselves run off dc there are different ways they may have designed it to handle the AC which will impact how well it works.
asdf38 is offline
post #4 of 5 Old 09-02-2012
tommays's Avatar
Re: LED: AC to DC
I looked at most everything Costco and Home Depot sold and between the bad color and nothing was really more than one step above junk
I sprung for the sensibulbs and have zero regrets
Now the boat has the best lighting it ever had with a current draw so low it is a non-factor
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #5 of 5 Old 09-02-2012
No more curry buffets
Ritchard's Avatar
Re: LED: AC to DC
If you want cheap 12v led strips, there is some good stuff on eBay for much less money for much more running length of LED strips. I got 5 meters of waterproof flexible strips for was it $20? They provide a wonderful glow to my cabin.
Make sure to get warm white.
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
