spinnaker size - Page 2 - SailNet Community
post #11 of 13 Old 09-05-2012
Senior Moment Member
SloopJonB's Avatar
Re: spinnaker size
The used sail sites say that if you don't plan on racing, a chute within 10% up or down of the "correct" specs for your boat will work.
SloopJonB is offline
post #12 of 13 Old 09-05-2012
Re: spinnaker size
Just to be sure you are familiar, there is a lot more to an AS than luff length. Where the draft is located, how deep it is, the cut of the foot, etc, etc. There are countless versions of AS sails, multiplied by the various different cloth weights.
Be sure you are very clear with your sail maker on the intended purpose for the sail and be sure they are very familiar with your boat. Is it all about downwind in light air, as your OP suggests? If so, the ideal sail for that condition would not allow for coming up on the wind much and could tear if the wind kicked up over 15 knots. If you want something more versatile, you will give up some downwind and/or very light air performance. Everything is a trade off.
Jeanneau 54DS
Minnewaska is offline
post #13 of 13 Old 09-05-2012 Thread Starter
flo617's Avatar
Re: spinnaker size
Well, I'm looking for a lighter air sail that would be somewhat flexible in its use and will carry the boat downwind and broad reach. if it allows me to do reaching in very light air, even better.
I do not need the ultimate performance downwind but my boat is a little heavy and the wind can get very light in the oakland estuary, it's too tempting to use the motor. In general, the wind in the sf bay tends to die as the winter sets in.
I want to movei n light air but I also want a sail that will keep together until say 10-15 knots and if I can keep my jib lowered but still hanked on in preparation for the passing of the SF slot that's even better.
I'll see if I can leave a little early and take measurement of my foredeck to be sure.
flo617 is offline
Tags
size , spinnaker
Spinnaker Size ncapener Gear & Maintenance 6 09-07-2010 08:51 PM
What size spinnaker for a 30 foot boat? jarcher Gear & Maintenance 1 08-08-2009 08:51 AM
How do you calculate spinnaker size needed Stillraining Gear & Maintenance 9 10-13-2008 12:34 AM
What size asymmetric spinnaker? CLucas Gear & Maintenance 11 05-23-2008 05:34 PM
N27, What size Spinnaker? russ1302 Newport 2 06-10-2007 09:22 PM
