12V Air Conditioning - SailNet Community
post #1 of 5 Old 09-05-2012 Thread Starter
S/V Jeanne Marie
My 120V AC is on its last legs and in keeping with trying to move everything to 12V I am considering replacing it with a 12V unit such as the one from Cruise N Comfort. Cruise N Comfort USA Marine Air Conditioning - Welcome This unit uses either 2 or three standard Danfoss compressors in a cascade arrangement to provide cooling. They are more expensive, and frankly the claims on the Cruise N Comfort site do not seem realistic.
Can anyone cite experience with 12V AC (or a previous thread)?
BTW I've had a hard time using the sailnet search function. You can imagine what a search for "Cruise N Comfort" returns, and there doesn't seem to be a boolean search option.
Thanks
Dennis
Dennis Templeton
S/V Jeanne Marie --- Morgan 51 cutter, Hull#1
Jackson Creek --- Deltaville, VA
dtempleton is offline
post #2 of 5 Old 09-05-2012
asdf38's Avatar
I have no help to offer on the AC but the trick to searching is using google. Add "site:sailnet.com" at the end of your google query. Much better than the built in search (this is true of most websites).
asdf38 is offline
post #3 of 5 Old 09-05-2012
Re: 12V Air Conditioning
If you are only planning on cooling one small cabin, it's worth looking into. You will probably have to ramp up your battery bank to accomodate it.
Catalina 34
chuck53 is online now
post #4 of 5 Old 09-05-2012
Max. BTU: 4000
Input Voltage: 12 Volts DC
Power consumption: low 18 amps high 35 amps ( Each setting can be manually selected or set to Automatically set)
You are not going to realisticly run this on batteries alone for long. A genset will need to be going. So going 12 is buying nothing. There market for this seems to be powerboats with power to spare from the engines.
ParadiseParrot is offline
post #5 of 5 Old 09-05-2012
tdw
Super Fuzzy Moderator
tdw's Avatar
Thanks
Dennis
Ignore the SailNet search function it is rubbish. Use google and you'll find that SailNet answer will pop up anyway.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
air conditioning j34035 Gear & Maintenance 4 07-20-2011 08:19 AM
Air Conditioning beanctr56 General Discussion (sailing related) 10 06-03-2011 10:39 AM
air conditioning kennya Gear & Maintenance 14 11-06-2006 10:42 AM
Air Conditioning dwbecker Gear & Maintenance 1 09-07-2006 12:31 AM
Air Conditioning PaulPryor General Discussion (sailing related) 1 08-03-2004 11:23 AM
