Hurrican Prep - I found a swivel - SailNet Community
post #1 of 2 Old 09-05-2012 Thread Starter
So far we have been pretty lucky with the storms this year in NC. But my preparation plans continue. Last year, for Irene, I anchored up our creek, with some protection from open wind, to 2 anchors and 2 trees. I tied the boat fore and aft with the 4 lines and it could not swing, it did fine even when one anchor rode chaffed thru. As I have mentioned in another hurricane anchoring thread, I would like to allow the boat to swing, but I have been reluctant to use a swivel as it is a single point of potential failure. Well while visiting a local marine consignment store I think I found a swivel I will feel comfortable with.
It is a Crosby 22 and may have actually been a swivel for a crane. On their website it is rated at a 4.5 ton safe load (it could likely be used to lift my 35' sailboat). The picture shows it with a new 5/8" rode, eye and shackle for size comparison; the center pin is nearly an inch in diameter. It weighs around 10 lbs, I approve of over sized ground tackle. And given that I will probably only use it a couple of days a year, the $15 price was right.
Now I just have to figure out exactly how to configure the 4 lines to my anchor points and redundant lines to the boat. I purchased a good size shackle (shown on the left) that will help me connect these lines to the swivel, a few more of these may be what I need.
I know it looks a bit unconventional, but I think it will work. Any comments?
CapnRon47 is offline
post #2 of 2 Old 09-06-2012 Thread Starter
Re: Hurrican Prep - I found a swivel
Questions:
IF I use a 10:1 scope for storm surge I assume that is from the anchors to the boat not just to the swivel? ( I can use chain from the 2 anchors to the swivel as I have 65' on each, but I will use 3/4" line from the tree to the swivel as that is what I have)
Should I use different dimensions lines from the swivel to the boat to provide shock relief (perhaps 3 strand nylon 1/2" line with 5/8" line backup that is longer)?
Now that I have more of a mooring setup (no longer fore and aft) maybe a line to one tree is sufficient (does the redundant tree line cause more potential for fouling than it is worth)?
I have a 25 lb CQR with short (10') of chain, would that be a good 'deadweight' to keep the swivel from moving around too much (or am I overthinking this)?
thanks,
Swivel Shackle or Not? T37Chef General Discussion (sailing related) 16 08-14-2013 11:36 AM
Does anyone know of a galvanized anchor swivel that will actually swivel? MedSailor Gear & Maintenance 18 09-04-2012 06:21 PM
Hurrican Earl heads toward the US East Coast Bene505 General Discussion (sailing related) 58 09-04-2010 08:02 PM
hurrican protection: which is safer? in the water or on the hard? faithab General Discussion (sailing related) 13 11-12-2006 05:14 AM
Hurrican holes in Florida kopykatps Cruising & Liveaboard Forum 0 03-24-2001 10:33 AM
