Overkill Solar? - SailNet Community
 2Likes
post #1 of 26 Old 09-05-2012 Thread Starter
71Irwin32's Avatar
Question Overkill Solar?
I'm putting two 9.5' long solar panels (unisolar pvl-68) on each side of my mast on the cabin top for long distant cruising. They'll only set about 8" above the cabin roof and be strong enough to stand on.
I've already got the panels and much of the T-6 for this, so I'm doing it, but I'm asking myself if it's overkill....taking too much space in that area. Pretty risky to get on them in any kind of swell......
71Irwin32 is offline
post #2 of 26 Old 09-06-2012
Closet Powerboater
MedSailor's Avatar
Re: Overkill Solar?
Electricity generation off the grid is like ammo. There is "enough" and "not enough" there is no such things as too much.
What's the worst that will happen? You can use electricity as to please, never conserve, and your batteries are always full and last years and years? Doesn't sound too bad to me!
MedSailor
MedSailor is offline
post #3 of 26 Old 09-06-2012
Aspiring to be a Mexican
sww914's Avatar
Re: Overkill Solar?
If you find you have too much power, just buy a watermaker, that'll fix that problem pretty quickly.
Skipper Jer likes this.
sww914 is offline
post #4 of 26 Old 09-06-2012
Keep in mind shading....you'll likely only benefit from one panel or the other depending on where your sun is during the day.
wouldrathersail is offline
post #5 of 26 Old 09-06-2012
Maine Sail's Avatar
Re: Overkill Solar?
Keep in mind that armorphous panels require about 50% more surface area to do the same job a monocrystalline or polycrystalline panel will do in terms of output. Also mounting on either side of the spar is a location that will suffer from some pretty extreme shading and panel performance, even with armorphous panels, drops off rapidly with any sort of shading.
A bimini frame can be a much better location that suffers from considerably less shading and an array 1/3 the size can often out perform a significantly larger array when the location chosen is chosen to minimize the potential for shading.
I will let others chime in on safety....
______
-Maine Sail / CS-36T
Maine Sail is offline
post #6 of 26 Old 09-06-2012 Thread Starter
71Irwin32's Avatar
Re: Overkill Solar?
Yes, I already have a watermaker that I'll be installing with the panels. That's specifically why I also purchased the panels. These panels in direct sun put out 4.2 amps each. The 90 psi pump for the watermaker requires 4.5 amps...the good news is I've installed 4, series 31 glass-mat 1100 amp batteries. Adding the wind generator should put me on easy street, unless of course, it breaks, but I'm only looking for 5 gallons per day, and the boat came with a 50 gallon water tank. If I've calculated reasonably well, the panels alone will fill the bill on sunny days, by themselves.
Safety is my biggest apprehension, but these particular panels are tough as nails and will last. I did measure the loss from shading, it's fairly dramatic, thus the wind generator added next. Really, if you don't have wind for the wind generator, you might as well drop your sails and rely on the panels.
My old Irwin has a very long boom. It reaches only one foot or so shy of the end of the cockpit, so the panels would need to be over the transom.
I really intend on being able to set out in the middle of nowhere and enjoy the ocean, and not have to go anywhere. Fish, write, compose music.....what ever I feel like doing.
post #7 of 26 Old 09-06-2012
Barquito
Barquito's Avatar
Re: Overkill Solar?
Are these panels in a location you might need to stand? If so, just throw some Interlux non-skid on there, and you will be good-to-go.
Valiant 32
Barquito is offline
post #8 of 26 Old 09-06-2012
tommays's Avatar
Re: Overkill Solar?
68 watts seems really BAD for the size your giving up when my tiny 24" pannel puts out 40 watts ?
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #9 of 26 Old 09-06-2012
sww914's Avatar
Re: Overkill Solar?
I didn't read very thoroughly the first time around.
So you have two 68 watt panels? That's it?
I have 3 200 watt panels and it's enough without the watermaker. With a fridge and a watermaker I may still need to run the engine.
I think you may have miscalculated something about your watermaker. They need about 1000 psi, not 90.
The watermaker I just bought draws 20 amps. Not 20 amps of 12v DC, 20 amps of 110v AC, so that will be 183 amps of 12v without factoring in any inefficiencies.
sww914 is offline
post #10 of 26 Old 09-06-2012
Closet Powerboater
MedSailor's Avatar
Re: Overkill Solar?
What about mounting them vertically or nearly vertical on the cockpit rails/lifelines? I've seen this done and they act as lee cloths. It seems you would be giving up a lot in sun angle but you wouldn't have to worry about shading, or stepping on them.
I've seen it done often enough that there must be some good data our there on the losses from doing it.
MedSailor
Solar deck instead of solar panels ulferlingsson Gear & Maintenance 34 01-31-2013 05:03 AM
solar help smallboatlover General Discussion (sailing related) 7 08-16-2012 04:20 AM
Anyone bought solar panels from Sun Solar? justonemoreproject Electrical Systems 1 04-18-2012 05:08 PM
[Overkill?] New rules for visiting the U.S. now enforced Valiente Cruising & Liveaboard Forum 26 02-11-2008 01:43 AM
think they use solar ? sailusvi General Discussion (sailing related) 0 10-08-2007 08:12 PM
