09-06-2012
Re: rope clutches
Originally Posted by americanfrog
thanks all - I like the spinlock design a lot better and would go that route, but i want to use the originally fittings, as it is pretty hard to get to a backplate with the way the deck is laid out on my boat. Thanks for the tip on replacement also, at this cost makes sense to get new ones, rather than rebuild.
thanks
Frederick
Pardon My French
Seattle
You don't need a backing plate for a set of clutches. All the load is parallel to the deck. Fender washers are all you need. The only down side is filling the old bolt holes. Hopefully the footprint of the new covers the old! For that reason I can understand replacing like for like.
1979 Santana 30 Tall Rig
Hull#101
