Manual or Electric Windless?? - Page 3 - SailNet Community
 7Likes
post #21 of 32 Old 09-06-2012
Re: Manual or Electric Windless??
I am fat and fat people like power everything.
ParadiseParrot is offline
post #22 of 32 Old 09-07-2012
Wish I never found SN!
SimonV's Avatar
I have had both. A true, manual only winch is simple and easy to use usually giving 8"(200mm) on each double stroke (forward and back) the handle needs to be a bout 3' for ease or use. An electric winch is a godsend (when they don,t break down )they are about double the speed of a manual but if they do break down and you need to do it manually they are lacking in efficiency especially the low line designs. The worst enemy of an electric anchor winch is lack of use.
bvander66 likes this.
Simon
I miss my boat
Brisbane
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #23 of 32 Old 09-07-2012
Bluenoser
jimjazzdad's Avatar
One more vote for the power windlass. I have an older SL 1500 horizontal windlass that lives undercover in the anchor locker on my boat. With a purported 1800# pull, I am able to recover the anchor while singlehanding. It has a chain gypsy and a capstan for rope as well; this is very handy for hoisting someone up the mast and I once used it to kedge off the beach when the boat went ashore during a hurricane (windlass paid for itself right there!)
I have a 210 AH house battery bank that is connected to the windlass by 2/0 cables. As others have suggested, I usually run the engine while recovering the anchor, so the drain on the batteries is minimal.
Without my powered windlass, I would probably would not do the kind of gunkholing I enjoy.
jimjazzdad is offline
post #24 of 32 Old 09-07-2012
Originally Posted by SimonV View Post
.....The worst enemy of an electric anchor winch is lack of use.
And you should disassemble, clean and re-grease annually. Which reminds me.........
Jeanneau 54DS
Minnewaska is offline
post #25 of 32 Old 09-07-2012
johnnyquest37's Avatar
Originally Posted by Ninefingers View Post
Quick question!
Some of you use the electric windlass while single handed. If it's not rated to pull the boat towards the anchor, how do you use to retrieve? Do you just assume that 1 knot of bot speed is about what the windlass retrieves at and motor forward at that speed?
In light air, I pull the rode until I come to chain, then use the windlass (if I use it). If there is wind, I run the rode back to the cockpit and use a winch and steer/throttle. Once I am more or less over the anchor, I take the rode forward and finish off with the windlass. Not sure what I would do if I had all chain rode.
[/B]S/V Wind Orchid
Catalina 350 (hull# 273)
Annapolis, MD
LET'S GET SERIOUS ABOUT REMOVING POLITCAL TAG LINES -- NOW!
johnnyquest37 is offline
post #26 of 32 Old 09-07-2012
Bluenoser
jimjazzdad's Avatar
I have an all-chain rode (3/8" BBB) on an SL 1500 (1800# pull). When I am "solo" retrieving the anchor with my windlass, I bring it in a few feet at a time, stopping when I hear the windlass motor loading up. Then the weight of the chain (the catenary) tends to pull the boat forward towards the anchor. Then I start all over again...repeating until the anchor breaks out...then its "get it in quick and get back to the helm"
jrd22 likes this.
post #27 of 32 Old 09-07-2012
You can get a remote windlass switch at the helm. Very convenient, if short handed. But you are still guessing a bit on helm control. We have one, but its relegated to minor adjustments. We always have someone on the foredeck with deploying and retrieving.
Jeanneau 54DS
post #28 of 32 Old 09-07-2012
ebs001's Avatar
I had a manual windlass for a few years and then switched to an electric. I would never consider a manual again.
Given the option between connecting the windlass to a house bank or a start battery, I would choose the start battery. A proper start battery is rated in cold cranking amps and is more suited to a windlass type electrical load which is high amps for a relatively short duration. I always run my motor when using my windlass so charging is not an issue.
ebs001 is online now
post #29 of 32 Old 09-07-2012
BJV
We anchor a lot (liveaboard in the Bahamas) with a 45lb anchor and 200' of chain. We have a two speed manual (old sea tiger) with a 4' bar. In the high speed slot it hauls in a foot for every double stock. At slow speed it draws in about 6" for each double stroke but pulls our 30K lb boat forward.
We usually take our time, both setting and hauling the anchor, so the added time has never fussed us.
I admit there are times I wish I had a powered windlass, but the one I desire/need for our boat is out of our price range at this time. If we find our physical condition deterioate we will likely make that plunge, looking at a horizontal lofrans or ideal.
bvander66 is offline
post #30 of 32 Old 09-09-2012 Thread Starter
Joesplace's Avatar
Smile Re: Manual or Electric Windless??
WOW, great comments! So here's what I've done:
Yesterday I purchased a Lewmar Pro-Series 1000 Windlass w/hand held remote, 100 ft 5/16" G-4 HT chain, 300 ft 5/8" 8-strand nylon rope, 1 group 27 starting battery w/box and a 3 bank battery charger.
I know Lewmar has mixed reviews but what doesn't these days . . .
I'll let everyone know how the project turns out. Thanks again for all the assistance!
joe
chucklesR likes this.
Joesplace is offline
Anyone have experience rebuilding vertical electric windless ? lukinc Pacific Seacraft 9 11-11-2016 05:29 PM
question regarding electric head vs manual our38 Gear & Maintenance 26 08-05-2013 08:36 PM
electric vs manual toilets rackham the red Electrical Systems 7 06-26-2012 09:29 AM
Thinking of installing a manual windless bkseawolf General Discussion (sailing related) 5 07-23-2010 01:05 AM
Manual to Electric Fuel Pump flintda Gear & Maintenance 2 02-20-2006 12:39 PM
