-   -   2QM15 Fuel System Need Help (http://www.sailnet.com/forums/gear-maintenance/91835-2qm15-fuel-system-need-help.html)
Lanky55 09-07-2012 12:20 PM
I just bought a San Juan 28 knowing the engine hadn't ran in about 2 years. I have pumped out the old fuel, changed the filters (that were plugged), had the injector pump checked out, bench tested and radared and still can get this thing to run. Now I am questioning the mechanical pump and the volume of fuel that it is supplying to the injector pump. I have been looking online for a new mechanical pump but... I need help, Suggestions? Questions? Fire away... thanks
DRFerron(
)12:12 PMthis is
Lanky, you should copy this into a new thread in the gear and maintenance forum (also in the general chat area - someone there may be able to help).
ParadiseParrot(
)12:12 PMthis is
change filter,,bleed
DRFerron(
)12:13 PMthis is
Or, our resident Parrot may have an idea. :)
ParadiseParrot(
)12:13 PMthis is
if it ran prior to fuel filter being pplugged then its air in system
Lanky55(
)12:17 PMthis is
It did run prior, it just quit on the guy pulling up to his mooring. How much quantity of fuel should the mechanical pump produce? when I manually pump it, it only appears to push fuel in the last 1/4 in of the thumb pump stroke. I have fuel up to the injector pump. none beyond it on the high side.
Press enter to send your message
