BATTERY CHARGERS - SailNet Community
post #1 of 3 Old 02-27-2004 Thread Starter
BATTERY CHARGERS
I am in the market for a battery charger for my Santana 35 which has a very basic 2 bank 12V system. The boat will be used for daysailing and occasional overnighters. Any recommendations would be appreciated.
drynoc is offline
post #2 of 3 Old 02-27-2004
Mr. Bill
BATTERY CHARGERS
There are several good articles on this website on battery charging/power issues, so I''d start there. If you don''t use your batteries much, I''d consider a solar panel to keep them charged up. Or, if if you have access to shore power, a small built-in, 6-10 amp battery charger is probably all you''ll need. You might also consider an alternator upgrade.
I''ve got an 85 a/h battery on my boat that I only need a couple times a year for the position/interior lights (I also carry a hand-held VHF & GPS). So I have to charge up my battery (portable GUEST 10A) a lot more than it''s used. My plan is to go with a solar panel in the near future, and maybe upgrade to a AGM battery.
e-27 sailor is offline
post #3 of 3 Old 02-27-2004
BATTERY CHARGERS
Most of us charge our batteries using the engine, no?
hamiam is offline
Solar Power for Battery Charge KnotaClew23 Gear & Maintenance 1 09-23-2005 03:40 PM
battery isolator with starter/generator? owenmccall Gear & Maintenance 1 07-21-2004 07:58 AM
Starter or House Battery? rrobar Gear & Maintenance 2 12-30-2003 03:56 PM
Battery combiner vs battery isolator prelude General Discussion (sailing related) 2 07-09-2003 08:31 AM
Wiring set-up for battery switch. pehrst Gear & Maintenance 6 06-18-2002 05:51 PM
